Mondrian Buyers Guide
Revision as of 05:41, 30 December 2014 by Glenn (talk | contribs) (catchg)
Mondrian Documentation
Temp. BOM
XY-gantry
  • 5 20x20mm extrusions of the desired length
  • 4 upper corner.stl
    • 6 m4x8
    • 6 T-nut
    • 1 m3x25
  • 2 y-sliders.stl
    • 1 nema14
    • 1 pulley
    • 4 m3x30 bolt
    • 2 603zz bearing
    • 6 zip-ties
    • one length of belt (extrusion length + 40mm)
  • 1 x-carriage.stl
    • 1 nema14
    • 1 pulley
    • 4 m3x30 bolt
    • 2 603zz bearing
    • 6 zip-ties
Z cube
  • bottom plate
  • 4 20x20mm extrusions of the desired length
  • 1 nema 17
    • 4 m3x12
    • 4 m3 large washer
    • 2 m3x25 "idler"
      • 3 m3 washer
      • 2 623zz bearings
      • 1 m3 large washer
      • 1 m3 nylock
  • a closed belt (extrusion length*4 +a little margin) (e.g.: ~1300 mm for a machine based on 300mm extrusion [1] (UK RS Stock Code: 474-5252) or 950 for a 200mm version [2])
  • 4 corner-base
    • 1 m5 threaded rod (lenght of Z extrusion +25mm, e.g.: 325mm for a MXX3)
    • 1 T2.5 pulley
    • 2 m5 nut
    • 1 m5 nylock [3]
    • 2 MR105 bearing (5x10x4 mm)
    • 2 T-nut
    • 2 M4x8
  • rear-plate
    • power supply
      • 2 m3x8
      • 2 m3 nut
    • power plug
      • 2 m3x8
      • 2 m3 nut
    • electronic board
        • minitronic : 4 m3x12 + +8 m3 nut + 4 m3 nylock
  • bed-plate
    • 4 Z-slider.stl
    • 8 m5 nut nylon
    • 4 m3x12
    • 4 m3 nut
Extruder
  • 2 extruder-idler.stl
    • 3 m3x8
    • 1 nema 14
    • 1 drive-gear
    • 1 m3x20
    • 1 603zz bearing
    • 2 m3 washer
    • 2 m3x35
    • 2 springs
    • 2 m3 nut
    • 1 ma-12-03-m5 pneumatic fitting
    • 1 m5 nut
FoldaRap Dual Hotend
  • 2 reprappro one piece nozzle (and a short lenght of ptfe tube)
  • 2 heater block
    • 2 thermistor
    • 2 heater cartridge
  • 1 heatsink block
  • 2 ma-12-03-m5 pneumatic fitting
  • 1 heatsink
  • 1 40mm fan
  • 2 500mm ptfe tube (bowden)
Other Tools
  • plotter
  • j-head
  • prusanozzle
  • bio-printing
Shopping list
  • Linear bearing pads
    • you are lucky if you're in the US -> 80/20 store
    • for EU, you'll find some resellers like westgroup.co.uk (I listed some spares on emakershop too)
