Motor Shield Standard
Revision as of 11:12, 5 November 2017 by Jobo (talk | contribs) (add standard, as proposed)
A4988, DRV8825, what else can you put on a blank template that fits on the Pololu type interface?
The board is 15.2x20.3mm, 0.6x0.8" [1] pololu.com
The A4988 chip is 5x5mm with about 1mm height
The DRV8825 chip is 6.9x10.2mm datasheet
Drill guide
Polulu description
Tha author would like to have a 3.3V voltage adapter soldered in so that the pins can be used to power a 3.3V DC motor.
Text and concept, copyright under the Do What the Fuck You Want to Public License, version 2, or, at your option, any later version.
