Mulbot
Revision as of 21:25, 29 September 2019 by 3DPrintingworld (talk | contribs) (Files and Documentation)
Crystal Clear action run.pngMulbot
working
Mulbot
General
Description A mostly printed printer that utilizes 3D printed recirculating bearing ball housings and 3D printed kinematics for motion.
License GPL
Team Members 3DPrintingworld
Based-on I3
Files GitHub Thingiverse
Forum Mostly Printed Printers FB Group
Categories Category:3D printers
Machine Specifications
Current Version DL1.0
Dimensions Length: 461mm
Width: 377mm
Height: 402mm
Build Envelope Length: 200mm
Width: 175mm
Height: 150mm
Materials Printed PLA, TPU, PETG
Replication No
Build Cost (≈) $250-300
Technology FFF
This article is about the Mulbot Printer.
PLEASE NOTE: This is the current home for community generated documentation (Please Contribute!).
The Mulbot is an open source Mostly Printed 3D printer that features a 3D printed frame, bearing blocks, and drive systems. The original goal for this project is to further push the Rep Rap concept and to 3D print more than just the frame. As a result there are no purchased bearing assembles or drive systems on this printer.
This printer utilizes square rail type 3D printed housings for linear bearings. Since the bearings and rails are printed they have been integrated into the frame members. 4.5mm G100 Stainless Steel bearings balls are used to recirculate through the bearing housings to reduce fiction and to provide preload to remove bushing slop.
All three of the printers drive systems are 3D printed as well. The Y-axis is driven by a 3D printed herringbone gear rack and pinion. The combination of 3D printed drive and idle pulleys and a TPU belt drive the X-axis hot end carriage. While the Z-axis utilizes 3D printed trapezoidal lead screws and nuts to translate the hotend vertically.
Specifications
Print Surface:
  • 8-1/2” Square Floating Glass Bed
Print size:
  • 175mm x 200mm x 150mm (dual fan shroud)
  • 145mm x 200mm x 150mm (surround shroud)
Required Print Volume:
  • 250mm x 210mm x 210mm
The original Mulbot was printed on a Original Prusa MK3
Filament Used
  • Everything is designed to be printed out of PLA with the exception of the TPU timing belt.
  • Uses less then 2kg of filament.
Non-Printed Parts
