NEMA 17 Stepper motor
A NEMA 17 stepper motor is a stepper motor with a 1.7 x 1.7 inch (43.2 x 43.2 mm) faceplate. The NEMA 17 is larger and generally heavier than for example a NEMA 14, but this also means it has more room to put a higher torque. However, its size is not an indication of its power.
Dimensions
Suppliers
There are many online Shop selling different types of motors Below is a non-exhaustive list of possible motors and suppliers.
You are welcome to add information on a stepper motor/vendor you encounter, but please add only steppers not other motors which were tested to actually work on some or all printer.
Manufacturer | Model | Holding torque | Rated voltage | Shaft | Step angle | Motor length | Additional notes | Vendor (shipping location) |
3D Acessories Hub | SH 47-1704 A | 43 N·cm | Ø 5 mm Dual | 1.8° | 42 mm | 3D Acessories Hub (IN) | ||
Casun | 42SHD0404-22 | 52 N·cm | 3.84 V | Ø 5 mm Single | 1.8° | 48 mm | DIYTechShop (US) | |
Kysan | 42BYGH4803 (SKU 1124030) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm | Kysan (CN) XYZPrinters (NL) | |
Kysan | 42BYGH4803-DC (SKU 1124090) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm | Same as 42BYGH4803, but with flat on the shaft. | 3D Maker World (US) Ultibots (US) |
Kysan | 1040222 | 88 N·cm | 2.6 V | Ø 5 mm single | 1.8° | 48 mm | Gear ratio: 5.2:1 | 3D Maker World (US) |
LDO Motors | LDO-42STH47-1684A | 50 N·cm | 2.8 V | Ø 5 mm single or dula | 1.8° | 47 mm | Also with flat on the shaft available. | LDO Motors (CN) |
Lin Engineering | 4118S-62-07 | 31 N·cm | Ø 5 mm | 1.8° | The Cupcake CNC uses several little 4118S-62-07 stepper motors. Per phase: 2.5 A, 0.93 mH. | |||
Longs Motor | 17HS4417 | 40.0 N·cm | 2.6 V | Ø 5 mm single | 1.8° | 40 mm | 2PrintBeta (DE) | |
Mercury Motor | SM-42BYG011-25 | 23.0 N·cm | 12 V | Ø 5 mm single | 1.8° | 34 mm | Rated voltage higher than ideal for running on 12 V current chopping drivers. | Abra (US & CA) Akizuki Denshi Tsusho (JP) |
RobotDigg | 17HS1011-20B | 28.0 N·cm | 4.8 V | Ø 5 mm single | 1.8° | 34 mm | Also with flat on the shaft available. | RobotDigg (CN) |
RobotDigg | 17HS3001-20B | 40.0 N·cm | 2.0 V | Ø 5 mm single | 1.8° | 40 mm | Also with flat on the shaft available. | RobotDigg (CN) |
RobotDigg | 17HS5005-S24 | 44.0 N·cm | 3 V | Ø 5 mm double | 1.8° | 48 mm | Double Shaft | RobotDigg (CN) |
RobotDigg | 17HS6002-27B | 65.0 N·cm | 4.05 V | Ø 5 mm single flat | 1.8° | 60 mm | Also with flat on the shaft available. | RobotDigg (CN) |
Unknown | 17HD2038E | 45.0 N·cm | Ø 5 mm single | 1.8° | EckerTech (CA) | |||
Unknown | 17HS19-1684S | 55 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 47 mm | Custom model. | Reprap Austria (AT) |
Servo Corporation | KH42JM2B087C | 33 N·cm | 6.7 V | Ø 5 mm single | 1.8° | 42 mm | Custom built. | DIYTechShop (US) |
SOYO | SY42STH47-1206A | 31.1 N·cm | 4.0 V | Ø 5 mm single | 1.8° | 40 mm | Pololu (US) | |
SOYO | SY42STH47-1504A | 55.0 N·cm | 2.8 V | Ø 5 mm | 1.8° | 47 mm | Flat on the shaft. | LulzBot (US) |
SOYO | SY42STH47-1684A | 43.1 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 48 mm | Some vendors have longer than standard cables. Per phase: 1.68 A, 2.8 mH. | 3Distributed (UK) fabberworld.com (CH) |
SOYO | SY42STH47-1684B | 43.1 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 48 mm | Same as SY42STH47-1684A, but double shaft. | LDO Motors (CN) Mendel-Parts (NL) |
Thingibox | TB35HT36-1004A | 35.3 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 36 mm | Thingibox (ES) | |
Thingibox | TB35HT36-1004B | 35.3 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 36 mm | Thingibox (ES) | |
Trinamic | QSH4218-51-049 | 49 N·cm | Ø 5 mm | 1.8° | 47 mm | Tested on MakerBot Cupcake CNC | Reichelt (DE) | |
Wantai | 42BYGH W811 | 47.0 N·cm | 3.1 V | Ø 5 mm | 1.8° | 48 mm | Variant with flat on the shaft available. | Cubic-Print (DE) electronic-things (DE) |
Wantai | Custom for QU-BD | 49.0 N·cm | 3.6 V | Ø 5 mm single | 1.8° | 48 mm | QU-BD (US) | |
Unknown | Unknown | 32.4 N·cm | 2.8 V | Ø 5 mm single | 0.9° | 43 mm | MatterHackers (US) | |
Makemendel | 4.4 Kg·cm | 2.8 V | Ø 5 mm single | 1.8° | 47 mm | Makemendel (IN) |
These were listed as "not tested" earlier, so your mileage may vary:
Lin Engineering | 417-11-48-02 | 7.0 N·cm | Ø 5 mm | 1.8° | 28 mm | May be too weak. | Alltronics (US) | |
Lin Engineering | 4018X-07-04 | 11.0 N·cm | Ø 5 mm | 1.8° | 26 mm | May be too weak. | ||
Lin Engineering | 4118L-25P-07R0 | 48.5 N·cm | Ø 5 mm | 1.8° | 48 mm | Alltronics (US) | ||
Nidec Servo | KH4248-B95101 | 48 N·cm | Ø 5 mm single | 1.8° | 48 mm | Mechapro (DE) | ||
Oriental Motors | PK244-01AA | 33.0 N·cm | 5.6 V | Ø 5 mm single | 1.8° | 39 mm | Bipolar/Unipolar. Holding torque/volts listed for Bipolor mode | eBay? (Worldwide) |
Oriental Motors | PX243M-03AA | 20.0 N·cm | single | 0.9° | 42 mm | Interinar Electronics LLC (US) | ||
Oriental Motors | PX243M-01AA | 15.0 N·cm | Ø 5 mm single | 0.9° | 33 mm | Uses Imperial #4-40 TPI mounting holes instead of M3 metric. | Interinar Electronics LLC (US) | |
Oriental Motors | PKE245DA-L | 55.0 N·cm | Ø 5 mm single | 1.8° | 47 mm | Oriental motor (JP/US) | ||
Rugao Xinhe | 17H185H-04A | 43.8 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 42 mm | AusXmods (AU) | |
Rugao Xinhe | 17H185H-04B | 43.8 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 42 mm | AusXmods (AU) | |
SANYO DENKI (Japan) | KH42KM2R001 | 45 N·cm | Ø 5 mm | |||||
Wantai Motor | 42BYGHM809 | 48 N·cm | 3 V | Ø 5 mm | 0.9° | 48 mm | SparkFun (US) | |
Custom | 42BYGH404 | 31 N·cm | Ø 5 mm single | 1.8° | 49 mm | MPJA (US) |
Part number decoding
You can decode the part number written on Shinano Kenshi motors with the SKC Stepping Motor Part Number decoder at Shinano Kenshi: "Stepping Motor Operation & Theory".
You can decode Lin Engineering part numbers written on it with the "Lin part number system" decoder on p.1 and p.2 of the Lin Engineering Catalog. Page 9 of the Lin Engineering catalog explains the part numbering system.
