NewHost Skeinforge
Revision as of 06:37, 11 January 2015 by Glenn (talk | contribs) (catchg)
This page describes something which is no longer the most recent version. For the replacement version see: ???
This is a Special Skeinforge Build on version: 2010-04-27 00:14:23 CET beta This is the Last Version with a working Comb-Funktion.
It is for the new RepRap-Host reprap-mendel-20100806.zip 63.0 MB 2010-08-06
The Export.py is Patched to delete the M-Codes.
def getNonskipped( gcodelines ):
  "Skip lines containing undesired commands."
  result = ""
  for line in gcodelines.split('\n'):
    if line.startswith("M101"): continue  #lines to skip
    if line.startswith("M103"): continue
    if line.startswith("M105"): continue
    if line.startswith("M108"): continue
    result += line + '\n'
  return result
Created by Peer
Old Version: File:NewHost Skeinforge.zip
This is a Special Skeinforge Build on version: 2010-09-21 21:28:31 CET beta This is the Last Version with a working Comb-Funktion.
File:31 reprap python beanshell-Patched for Mendel.zip
File:33 reprap python beanshell-Patched for Mendel-Host.zip
http://fabmetheus.crsndoo.com/
Put this in your "alterations" folder and you dont need a Patch :)
File:Replace.csv
--Stoffel15 12:58, 2 November 2010 (UTC)
