North90's hot-end V2
Revision as of 23:36, 13 December 2011 by North90ty (talk | contribs) (Created page with '{{Development |image = North9o_he_v2_finished.jpg |name = Easy to build Hot End V2 by North90ty |description = Easy to build Hot End V2 by North90ty |status = Working |license = …')
Release status: Working
This is an upgrade of: North90's hot-end This Hot End is designed to be build with simple tools and without the need for great engineering skills.
Thermal design
see: http://www.reprap.org/wiki/North90%27s_hot-end#Thermal_design
Tools and supplies
  • Drill + drill bits
  • Vice
  • Tube-cutter
  • File(s)
  • Cutting oil (olive oil works great)
  • Stainless steel tube with an outside diameter of 1/4" (6.35mm), thin wall diameter
  • PTFE tube 1/8"(3.18mm)(3.5mm is fine too) inner diameter and 1/4" (6.35mm) outer diameter
  • welding nozzle (0.6mm)
  • Piece of aluminium sheet 5-6mm thick
How to get the Hot End to print
  • Clean out all parts. You do not want pieces of metal to jam in the nozzle.
  • Add the heater and temperature sensor of your liking.
  • Mount to your extruder.
  • Print.
