Ohm/How to build an OHM
Revision as of 03:29, 10 November 2013 by KalleP (talk | contribs)
Introduction
The Open Hybrid Mendel (OHM) has several advantages over the generic Mendel model. Mainly, it is more flexible. The extruder carriage and printing board are designed to easily pop off the machine without unscrewing any parts.
All STL files mentioned in this article are referring to, and can be downloaded from the OHM Parts section.
Mechanical Construction
Frame
Frame Triangles
Parts
Total # of assemblies: 2
Name Qty/assembly Total Qty Type
Camiel_frame_vertex_6off 3 6 RP
prusa_bar-clamp_4off 1 2 RP
m8-nut 14 28 Fastener
m8-washer 14 28 Fastener
m8-threaded rod D 3 6 Threaded Rod
Reprapped parts
Assembly
(The above list of parts is accurate. The assembly should reflect this) (Assembly guide. Delete this note when section is finished)
Tips
When you assemble the frame triangles, it will be easier if you assemble the two top vertices the last. To insert the rod into the vertices, you can tie two nuts tight together and then use a wrench to screw in the rod.
Connecting the Triangles
Parts
Total # of assemblies: 1
y-motor-bracket_1off_mod3-15 1 1 RP
y-idler-bracket_1off 1 1 RP
m4x40-cap 4 4 Fastener
m4-washer 12 12 Fastener
m4-large OD washer (3/16 fender washer) 8 8 Fastener
m4-nylock 4 4 Fastener
m8-nut 44 44 Fastener
m8-washer 44 44 Fastener
m8-threaded rod E 4 4 Threaded Rod
m8-threaded rod F 3 3 Threaded Rod
Reprapped parts
Assembly
(The above list of parts is accurate. The assembly should reflect this) It is a good idea to assemble the pulley bearings before putting the motor mount and idler on (Assembly guide. Delete this note when section is finished)
Tips
It is easier to assemble the triangles, if connected both ends first, and then connect the bottom two rods.(Extra tips to help assemble. Delete this note when section is finished)
Z Drive System
Z-Axis Motor Mounts
Parts
z-prusa-motor-mount_2off 1 2 RP
z-bar-top-clamp_2off 1 2 RP
m3x10-cap 4 8 Fastener
m3-washer 4 8 Fastener
m8-nut 2 4 Fastener
m8-washer 4 8 Fastener
Stepper Motor 1 2 Motor
Reprapped parts
Assembly
(The above list of parts is accurate. The assembly should reflect this) Leave the smooth rod clamps loose and save the threaded rod for "connecting the x and z axis" section, since the x assembly needs to slide on before these are attached. (Assembly guide. Delete this note when section is finished)
Tips
Assembly of Z-axis can be started from sticking everything together in one rod. Settling all the parts (including the two top vertices for the frame triangle) on Z axis and connecting them with rod at one side, then insert the rod for the other side.
X-Z Assembly
X-Axis Idler Bracket
Parts
x-end-bracket_1off 1 1 RP
x-180-z-bearing-plate_2off 2 2 RP
x-bar-clamp-m3_4off 2 2 RP
m3x20-cap 4 4 Fastener
m3-nylock 4 4 Fastener
m3-washer 8 8 Fastener
m4x20-cap 2 2 Fastener
m4x40-cap 8 8 Fastener
m4-nylock 10 10 Fastener
m4-washer 26 26 Fastener
m4-large OD washer (3/16 fender washer) 4 4 Fastener
bearing-4x13x5 6 6 Bearing
Reprapped parts
Assembly
Tips
X-Axis Motor Mount
Parts
xaxis-motor-bracket_1off 1 1 RP
PSU_x_vert_sideplate_360_end_2off 2 2 RP
x-360-z-bearing-plate_2off 2 2 RP
x-360-z-bearing-plate-mirror_2off 2 2 RP
pulley_w-set_screw_2off 1 1 RP
m3x6 set screw 1 1 Fastener
m3-nut 1 1 Fastener
m3x10-cap 4 4 Fastener
m3-washer 12 12 Fastener
m4x16-cap 4 4 Fastener
m4x40-cap 6 6 Fastener
m4-nylock 12 12 Fastener
m4-washer 34 34 Fastener
bearing-4x13x5 8 8 Bearing
Stepper Motor 1 1 Motor
Reprapped parts
Assembly
Tips
X-Axis Vertical Bearing
See Mendel X-Axis for further information.
Parts
x-axis-side-plate-nut-jig_2off 1 2 RP
x-bar-clamp-m4_4off 2 4 RP
x-vert-drive-nut-trap_4off 2 4 RP
x-vert-drive-side-plate_4off 2 4 RP
m4-nut 4 8 Fastener
m4-nylock 4 8 Fastener
m4-washer 12 24 Fastener
m4x40-cap 8 16 Fastener
m8-nut 1 2 Fastener
Reprapped parts
Assembly
First, assemble the x-vert-drive-nut-trap_4off. To do this, you need a lighter, four m4 nuts and a m4x40-cap. Place an m4 Nut on the end of the m4x40-cap and heat with the lighter. Caution: Do not heat for too long or the m4x40-cap will become very hot.
Push the heated nut into one of the hexagonal holes in the x-vert-drive-nut-trap_4off. Repeat for all four nuts.
Screw x-vert-drive-side-plate-180-end_2off and x-bar-clamp-m4_4offtogether using m4x40-cap and washers. Do not screw them all the way in.
Screw x-vert-drive-nut-trap_4off into x-vert-drive-side-plate-180-end_2off using a diagonal pattern. Remember to use washers. Do not screw them all the way in.
Repeat previous steps to create other half. Make sure that you place the screws diagonally in a way that they do not interact with the other screws.
Place the x-vert-drive-nut-trap_4off in between the bottom half of the two sides and line up screws. Screw in the M4 screws until they sit in the nuts and are firmly in place. This could take some adjustment.
Place an M8 nut in between the two trap sides. Then screw the upper screw together. Tighten all screws in steps.
Tips
  • In some cases, though it is not necessary, it may help if you drill out the holes before assembling.
  • To help align the screw holes, place on screw in, clamp the parts, and drill the rest of the holes.
Assembling the X-Axis
Parts
m8-smooth rod A 2 2 Smooth Rod
Assembly
Tips
Connecting the X-Axis to the Z-Axis
Parts
pla_coupling_nophead-1piece_4off 2 4 RP
m3x20-cap 4 8 Fastener
m3-nylock 4 8 Fastener
m3-washer 8 16 Fastener
m8-nut 2 4 Fastener
m8-washer 2 4 Fastener
m8-threaded rod G 1 2 Threaded Rod
m8-smooth rod B 1 2 Smooth Rod
Reprapped parts
Assembly
Tips
Z and X axes Endstops
Parts
endstop-holder_microsw-1_small enstops_3off 1 2 RP
m3x20-cap 1 2 Fastener
m3-nylock 1 2 Fastener
m3-washer 2 4 Fastener
Reprapped parts
Assembly
Tips
OpenY Axis
Y-axis Guide Bars
Parts
y-bar-clamp_8off 4 8 RP
m4x40-cap 4 8 Fastener
m4-washer 8 16 Fastener
m8-smooth rod C 1 2 Smooth Rod
Reprapped parts
Assembly
Tips
OpenY Assembly
Parts
OpenY_Arm 90 - 180_2off 2 2 RP
OpenY_arm45 1 1 RP
OpenY_8mm Crossbar Mount_2off 2 2 RP
OpenY_8mm Belt Harness_1off 1 1 RP
OpenXY_bracket 2 2 RP
m4x20-cap 8 8 Fastener
m4x25-cap 4 4 Fastener
m4-nylock 16 16 Fastener
m4-washer 36 36 Fastener
m8-nut 4 4 Fastener
m8-washer 4 4 Fastener
m8-threaded rod H 1 1 Threaded Rod
bearing-4x13x5 12 12 Bearing
Reprapped parts
Assembly
Tips
Print Bed
Parts
bed-spring_4off 4 4 RP
m4x50-cap 4 4 Fastener
m4-washer 8 8 Fastener
Reprapped parts
Assembly
Tips
Motors, Belts and Endstops
Parts
endstop-holder_microsw-1_small enstops_3off 1 1 RP
m3-nut 1 1 Fastener
m3x20-cap 1 1 Fastener
m3x25-cap 4 4 Fastener
m3-nylock 1 1 Fastener
m3-washer 6 6 Fastener
Reprapped parts
Assembly
Tips
Extruder
Carriage
Parts
OpenX_Carriage_1off 1 1 RP
OpenX_arm_PSU_1off 1 1 RP
m4x20-cap 14 14 Fastener
m4-nylock 14 14 Fastener
bearing-4x13x5 10 10 Bearing
Reprapped parts
Assembly
Tips
Make sure you have a good hot tip before you attempt to install it. Ask around to see if the hot tip you are using is a good one. Quite often the extruder body or parts are not perfect. You must do a judgement call to determine if the parts are still usable. The extruder must still be accurate where it counts. You can also fix imperfections with a soldering iron to melt extra plastic that's in the way.
Motor Mount
Parts
Gregs_accessible_wades_v6 1 1 RP
Gregs_accessible_wades_idler 1 1 RP
HerringboneDrivenGear 1 1 RP
HerringboneDriveGear 1 1 RP
m3-nut 1 1 Fastener
m3-washer 4 4 Fastener
m4x25-cap 3 3 Fastener
m4x40-cap 2 2 Fastener
m4-nut 3 3 Fastener
m4-nylock 2 2 Fastener
m8-hobbed bolt 1 1 Fastener
m8-nylock 1 1 Fastener
m8-washer 2 2 Fastener
m8-smooth rod (stub) 1 1 Smooth Rod
bearing-8x22x7 3 3 Bearing
stepper motor 1 1 Stepper Motor
Reprapped parts
Assembly
(The above list of parts is accurate. The assembly should reflect this) (Assembly guide. Delete this note when section is finished) This unfinished part includes the main driven gear, idler and lastly the main section.
Tips
Hot Tip
Parts
metal base plate 1 1 Misc. Hardware
metal exruder shaft 1 1 Misc. Hardware
brass tip 1 1 Misc. Hardware
heat sink 1 1 Misc. Hardware
fireplace cement? 1 1 Misc. Hardware
m3x25-countersink 2 2 Fastener
nichrome wire 1 1 Wire
thermocouple 1 1 Wire
(These parts need to be more specific with details) (Parts needed for assembly. Delete this note when section is finished)
Assembly
Tips
When you feel like the tip is stuck, heat it up, and then use another piece of filament to quickly suck out the part that were stuck in the tip. (Extra tips to help assemble. Delete this note when section is finished)
Spool
Spool Assembly
Parts
Assembly
Tips
Spool Mount
Parts
Assembly
Tips
Electrical Construction
RAMPS
Motherboard
Ramps_Mount 1 1 RP
RAMPS 1.4 1 1 PCB
zip-tie 8 8 Fastener
Reprapped parts & motherboard
Connecting Power
Parts
AC Computer Power Adapter (12V, 6A) 1 1 Power Supply
Assembly
Connecting the Motors
Connecting the End Stops
Connecting the Hot Tip
Connecting the Thermocouple
RAMBO
Motherboard
Motor drivers
End Stops
Hot tip
