Ohm/How to build an OHM
Revision as of 18:42, 15 November 2012 by Afs2015 (talk | contribs) (Moved proposed updates to relevant areas.)
Introduction
The Open Hybrid Model (OHM) has several advantages over the generic Mendel model. Mainly, it is more flexible. The printing board is designed to easily pop off the machine without unscrewing any parts.
All STL files mentioned in this article are referring to and can be downloaded from OHM Parts section.
Mechanical Construction
Frame
To make the frame triangles, 6 frame vertices, 2 bar clamps and 6 threaded bolts are needed.
Frame Vertex part
Bar Clamp part
X-Z Assembly
Z Drive System
OpenY Axis
Carriage
Extruder
Spool Arm
