Omega
Revision as of 13:57, 14 December 2014 by Traumflug (talk | contribs) (Fix development template.)
Omega3D Documentation
Omega3D
Release status: experimental
[[image:Omega3dPlaceHolderSmall.png|center|190px]]
The Omega3D is one of the largest printers for it's price.
The Omega3D is one of the largest, most customizable, affordable RepRap printers.
Specifications
  • Printed Parts: ???
  • Non-Printed Parts: ???
  • Material Cost: ???
  • Cost: $900(not yet for sale, will be available after development is complete)
  • Printing Size: 400x400x400mm on plate, 460x460x460 with "Printed Bed"(See Below for more details)
  • Precision: .003mm (position/printing) depends on your setup
  • Speed: ??cm/s (position/printing) depends on your setup
Main improvements
This list is of the improvements and special features compared to most RepRap 3D printers:
  • large format
  • expandability, allowing for the creation of larger or smaller printers
Development
The Omega3D is currently in an "under-wraps" development stage and will be released when the development is complete.
History
Printed Parts
Frame type
The Frame of the Omega3D is constructed of lightweight, strong aluminum 20x20 extrusions.
pros:
- light and sturdy - modifiable
con:
- slightly more complicated construction method
Electronics
Stepper Motors
The Omega3D uses, including the extruder, 5 NEMA17 stepper motors. Two of these motors, the Z axis motors, are connected to the same stepper driver of the electronics. If using Wade's Extruder, its stepper motor needs a minimum holding torque of 40Ncm (0.4Nm). More information can be found on the Stepper Motor page.
Controller Electronics
About any RepRap controller works for the Omega3D. Required features: 4 stepper drivers, 1 thermistor input and 1 heater output for the extruder and optionally another thermistor/heater pair for the heated bed. Choosing the best one for your printer is mostly a matter of taste. For comparisons, see List of electronics, Comparison of Electronics and Alternative Electronics.
Extruder
Extruder The Omega3D uses a bowden extruder, adding flexibility and speed to the extruder nozzle.
Heated Bed
Heated Bed The basic model of the Omega3D does not include a heated bed, thus making PLA a recommended filament.
