Open Hybrid Mendel
Revision as of 21:53, 6 December 2012 by Asb5165 (talk | contribs)
Open Hybrid Mendel (OHM)
Release status: Working
A hybrid between Prusa and Mendel models using several improved pieces from the community
GPL
Parts - Here is the list of parts for the OHM: Open_Hybrid_Mendel/Parts.
Overview
The Open Hybrid Mendel (or OHM) is a project of the State College Reprap Users Group. It is a Mendel design, which uses both standard Sells Mendel parts, a Prusa Z drive, various redesigns from the community at large, and a number of small design improvements developed in our PSU Reprap class. It is so named due to this hybridization of designs, and obtains the 'Open' designation from the OpenX and OpenY axes it uses. The prototype for the OHM design was Etherdais_Unit_One
Expanding into the realm of the biological, the OHM is the basis for a Mendel-based PCR system, currently designated the RepRap Mullis.
Any Mendel can be broken down into 6 sub-systems, which are somewhat interchangeable between designs:
Frame - The OHM uses Camiel's thin shelled Vertex design, maintaining vertices similar to the Sells design, but using less filament
Y-axis - The OHM uses a modified OpenY, with an optoless belt harness, and a second 90/180 arm in place of the 90/270 arm. This demands two additional bearings, but we find the result is more stable, while retaining the benefits of the OpenY. A modified Sells y-motor bracket is used, which avoids printing an unused endstop holder from the original Sells design. The original Sells y-bar clamps seem well suited for mounting y-axis opto-endstops.
Z-drive system - The OHM uses a Prusa, double motor design for driving the Z axis, avoiding the large prints and continuous belt of the Sells Z-drive design. We still use Sells bar clamps to clamp the smooth rod to the Z-motor mounts, as they are compatable, and look sharp together.
X-Z assembly - Currently, the OHM build uses a standard Sells X-Z assembly, as described here in Mendel_X-axis. An important change in the design of the assembly is to be noted. The x vert drive side plate 360 end is no longer being used for future RepRap parts. A modified version of the 360 end is being used. The following pictures display the slight difference in their structures
Carriage - The OpenX carriage is the design of choice currently, with modifications to the Undercarriage Bracket and Arm that have been found to reduce side to side wobble and skew. For a list of changes, see the X Carriage section.
Extruder - We are in the process of finding a design which is more compatable with the TechZone steel hot tips we've been using recently, though the current design is a hack of herringbone extruder gears, and GregFrost's hinged wades extruder.
Spool Arm - The OHM uses an "in-house" design to support the PLA spools. See Spool Arm Design.
Download Zip: File:OpenHybridMendel 0.92.zip
Basic Rules
Any rules or warnings that should be established before using the OHM can be included here. For example, a safety related tip would definitely make a good addition to this section
Ongoing Development
There should be some information here. Anyone willing to include anything? The PonokoRepRap page is filled with links, so I feel that the OHM page needs to have something
-Build team attempting to implement a pre-cut plexiglass sheet as an alternative to the standard laser-cut wooden bed. The material warps easily, currently looking into workarounds to keep the bed level and unstressed. Printed-plastic springs are causing issues, may ditch them in favor of thin washers. Extra care will be required to not leave the heated tip resting on the bed, and maintaining proper Z-stops to prevent the tip from driving into the bed. [Nov 21, 2012]
See Also
State College RepRap Users Group
S.C.R.U.G. Main · The Make Space · Intercollegiate Future Society · Wiki Help
