P3Steel Proteins
Revision as of 16:11, 10 November 2013 by Jbabio (talk | contribs) (Created page with "== Proteins == In RepRap jargon, a vitamin is anything that you need to make a RepRap, which a RepRap can make itself. All parts were designed using '''OpenScad''', they are...")
Proteins
All parts were designed using OpenScad, they are reutilized parts from the Prusa 2 and Prusa i3 box. Font files available at:Josef Prusa's repository
STL files are available at:GitHub
Almost all the structure is made of steel so you will only need th following printed parts:
Carriage parts
Endstop holders
This part allow the attachment of the endstops to the frame. You will need 3 for a basic setup (homing axes) and 6 if you want to sense both ends of each axis.
Diferent endstops can be attached to the P3Steel printer. Here we list some options.
Endstop 1 Endstop 2 Endstop 3 Endstop 4
Image P3s endstop.png P3S Hall-O Endstop.jpg P3S hall endstop holder.jpg P3S endstop-clamp.jpg
Files x-end-motor-abs.stl Thingiverse Thingiverse Thingiverse
Sensor type Mechanical Magnetic Magnetic Not Specific
Author Josef Prusa schlotzz jridley Obijuan
X-Axis motor end
This part holds the X-Axis motor, fastens the Smooth rods of the X-Axis, holds two LM8UU bearings for the left Z-Axis smooth rod and the nut for the left Z-Axis threaded bar.
Diferent X-Axis motor ends can be fitted to the P3Steel printer. Here we list some options.
X Motor End 1 X Motor End 2 X Motor End 3 X Motor End 4
Image P3s xendmotor.png N/P N/P N/P
Files x-end-motor-abs.stl N/P N/P N/P
Author Josef Prusa N/P N/P N/P
Image Part (STL) Quantity Commentaries
P3s xendidler.png x-end-idler-abs.stl 1 X end idler
P3s xcarriage.png x-carriage.stl 1 X carriage
P3s ybeltholder.png y-belt-holder.stl 1 Y belt holder
Extruder parts
P3s biggear.png biggearmod_fixed.stl 1 Big Gear
P3s smallgear.png smallgearmod_fixed.stl 1 Small Gear
P3s extruder.png gregs-wade-v3-motor.stl 1 Extruder
P3s extruder idler.png gregs-extruder-v3-idler-mod.stl 1 Extruder idler
Optional parts
Photos
