Packed Binary GCode
Revision as of 19:01, 5 March 2013 by Bobc (talk | contribs)
Packed Binary GCode (PBG)
Bob Cousins
28 August 2012
Version 0.4
Goals:
  • reduce size of GCode data
  • compatible with RS274/NGC spec for all types of machine, e.g. for printers, milling, lasers etc
  • should be able to completely recreate ASCII GCode from compressed GCode with no loss of precision/data, comments
  • independent of machine, i.e. does not use machine units
  • extension for string parameters
  • doesn't require significant extra RAM for decoding
  • streamable format, not context dependent
Todo: embed binary data?
Todo: add bcd, or double?
Method
  1. GCode blocks are generally a list of <word letter> <number>, e.g. "G1", "Z1.5".
  2. There are 26 letters, plus a few other items like comments, checksum
  3. Therefore code letter is stored in 5 bits (0-31).
  4. Integers can be stored in 1,2 or 4 bytes, signed or unsigned
  5. Signed decimals stored in float (4 bytes)
  6. Comments and uncompressed data stored as null terminated string
  7. Therefore type stored in 3 bits (0-7)
Syntax
BNF syntax:
	gcode_line  ::= { gcode_command … } EOL_MARK;
	gcode_command ::= { gcode_word ... }  EOC_MARK ;
	gcode_word  ::= code_type {parameter};
	code_type ::= BYTE ( code << 3 | type );
	code ::= 0..30;
	type ::= 0..7;
	parameter   ::=  BYTE … ;  // 1,2,4 bytes or zero terminated string
	EOC_MARK ::= 0xF8
	EOL_MARK  ::= 0xF9
GCode word encoding
+--- 1 byte ---+-/ 0 to N bytes /-+
| CODE . TYPE  |      data        |
CODE + TYPE stored in 1 byte:
0000 0ttt 	CODE 0 = Checksum (*) (numeric data)
0000 1ttt 	CODE 1 = A  (numeric data)
1101 0ttt 	CODE 26 = Z (numeric data)
1101 1ttt 	CODE 27 = spare
1110 0111	 CODE 28 = Comment (type=string)
1110 1111	 CODE 29 = Uncompressed text (type=string)
1111 0111	 CODE 30 = String parameter (no word letter)
1111 1000	 CODE 31 = No data, where:
1111 1000	        0xF8 = End of command
1111 1001	        0xF9 = End of line marker
1111 1010		0xFA-
1111 1111		0xFF spare
todo: block delete?
TYPE:
   0 : unsigned byte (1 byte)
   1 : signed byte (1)
   2 : unsigned short (2 byte) //??
   3 : signed short (2 byte)
   4 : signed int (4 byte)
   5 : BCD decimal
   6 : float (4 bytes)
   7 : string (N+1 bytes)
BCD =
   0x0 .. 0x9 == 0..9
   0xA == '.'
   0xB == '-'
   0xF == end
Comparison of sizes:
Command 1: G1 E10810.1 F1000
Original size: 21 Bytes
Updated for errorcheck: N6654 G1 E10810.1 F1000 *65
Errorcheck size: 29 Bytes
repetier-protocol: 15 Bytes
3+2+5+3+2+2
Packed Binary Gcode: 17 bytes
