PiBot TB6600 Stepper Driver
Revision as of 01:19, 31 August 2013 by Panxinlong7373 (talk | contribs)
Part of PiBot Electronics,Stepper Driver
see files
PiBot TB6600 Stepper Driveris a part of PiBot electronics. It put forward a easy solution to make your 3D printer and CNC machine. Not only an electronic board, but also an PiBot-box which is similar to computer Host and you can easily handle it only plug few cables.
The PiBot TB6600 Stepper Driver is a [TOSHIBA TB6600HQ] based driver.
  • Features of stepper Driver
    • PWM chopper-type single-chip bipolar sinusoidal micro-step stepping motor driver.
    • BiCD 0.13 (50 V) process, Lower Ron: 0.4 Ω(typ.).
    • Output withstand voltage: VCC = 50 V.
    • Output current: IOUT = 5.0 A (absolute maximum ratings, peak, within 100ms);IOUT = 4.5 A (operating range, maximal. value);MoreStepper motor can choose. Solder 6*1W external resister sensor.
    • Thermal shut down (TSD) protection.
    • Under voltage lock out (UVLO) protection.
    • Over-current detection (ISD) protection.
    • Double input port: Anti-reverse structure IDC haeder( 8pin symmetrical input) & HT-396-4pin input (suit for DIY).
    • Stepless adjustable reference voltage.
    • Compatible the CNC Stepper Motor.
    • Offer an solution to change your CNC to 3D Printer.
    • Board size: 51.1*58.5mm ; fix hole: 43.9*45.7mm -Carry 60*60*10mm aluminum Heat sink which build-in fix hole and connection hole.
    • Auto half current, energy conservation.
    • photoelectric-isolation used in the input port,compatible more drive Level.
    • Programmable micro step - 1/1, 1/2A, 1/2B, 1/4, 1/8, 1/16.
    • Price for complete PiBot TB600 Stepper Driver $24,- (soldered, incl. 100mm cable and connector)
    • For purchasing or more information, please contact PiBot, or one of the resellers.
    • All parts are licensed under CC BY-NC-SA 3.0
Settings of Driver
PiBot TB6600 Stepper Driver all input pins build-in connect to GND with a 100KΩ resistance.
M1(input) M2(input) M3(input) Mode (Excitation) Illustrate
L L L standby mode (operation of the internal circuit is almost turned off) H-High voltage, L-Low voltage
L L H 1/1(2-phase excitation, full-step)
L H L 1/2A type (1-2phase excitation A type) (0%-71%-100%)
L H H 1/2B type (1-2phase excitation B type) (0%-100%)
H L L 1/4 (W1-2phase excitation)
H L H 1/8 (2W1-2phase excitation)
H H L 1/16 (4W1-2phase excitation)
H H H standby mode (operation of the internal circuit is almost turned off)
Auto\Latch(input) Effect Illustrate
L TSD and ISD functions return by either of turning on power supply again or
programming the ENABLE as H → L → H || default set to High
H TSD and ISD functions return automatically
TQ(input) Vref Voltage Ratio Effect Illustrate
L 30% of the input Vref decrease 70% Motor current default set to High
H 100% of the input Vref full current,more power
adjust the Vref to set the stepper motor current
100% Current Settings (Current value)
100% current value is determined by Vref inputted from external part and the external resistance for detecting output current. Vref is doubled 1/3 inside IC. Per the [TB6600 datasheet], the calculation for current is:
  Io(100%) = (1/3 × Vref) ÷ RNF
The average current is lower than the calculated value because this IC has the method of peak current detection.
RNF should be 0.68||0.68||0.68=0.2267Ω
Sometimes this value can be set by experiment, that Stepper motor not heating, small noise and the chip do not get too hot.
How to Build
    • solder surface mounting components
  • Use SMT soldering toolkit
    • Apply solder paste to every exposed SMD pad.
    • Place each SMD component on its appropriate pad.
    • Place populated board on a cold hotplate,turn hotplate on,board solders itself!
    • Solder in remaining through hole components.
  • If you without a soldering toolkit, you can also use an tweezers and an soldering iron finish them by manual.
    • solder through hole components
  • Use soldering toolkit
    • Insert through hole components.
    • solder all these pins to the pad.
    • solder chip in bottom layer
  • Solder the TB6600 in bottom
  • Be careful, please ensure no short cut and insufficient solder.
  • Test
    • Before plug in the power source, you first need to check the polarity of electrolytic capacitor, chip and diode.
    • Use an digital multimeter to test the resistance value of the power. Usually, it has a increase resister. Ensure no short cut and insufficient solder.
    • Now, you can plug in the power source, the power LED (red) lighten. Usually,the Run LED(green or red) lighten(it not related).
    • Connect the control pins and output pins(A1-Red A2-Green B1-Yellow B2-Blue or A1-Black A2-Green B1-Red B2-Blue), input signal,
  • stepper Motor and Driver Connection
A1(output) A2(output) B1(output) B1(output)
Red wire Green wire Yellow wire Blue wire
Black wire Green wire Red wire Blue wire
Pin Map
  1. Input, The IDC Header
Pin Name Function
1 Enable Control signal input. set to high input, set to low disable input.
2 direction Forward/reverse control. set to high CW, set to low CCW.
3 clk A pulse on this line will make the stepper motor advance one step in the desired direction.
4 GND Connect to the controller common ground.
5 GND Connect to the controller common ground.
6 clk A pulse on this line will make the stepper motor advance one step in the desired direction.
7 direction Forward/reverse control. set to high CW, set to low CCW.
8 Enable Control signal input. set to high input, set to low disable input.
  1. Input, HT-3.96mm-4pin header
Pin Name Function
  1. Input, HT-3.96mm-2pin header
Pin Name Function
1 Power + Input the power source "+" polarity. Limit input:0-45V.
2 Power - Input the power source "-" polarity.
  1. Output, HT-3.96mm-4pin header
Pin Name Function
1 A1 Output of Driver connect to Stepper motor A1-A2
2 A2 Output of Driver connect to Stepper motor A1-A2
3 B1 Output of Driver connect to Stepper motor B1-B2
4 B2 Output of Driver connect to Stepper motor B1-B2
Driver Comparison
Alternative sources for stepper drivers
Manufacturer Verified? Location Max current Microstepping Comments
PiBot_TB6600_Stepper_Driver (using Toshiba 6600HQ) Yes CN 0-4.5 A 1/1,1/2A,1/2B, 1/4,1/8,1/16
  • PiBot_Stepper_Driver Board is a opensource driver board.
  • it offer an solution that suit for your CNC mill and 3D Printer, easy convert your CNC into a 3D Printer.
  • NEMA14 and NEMA17 stepper motor compatible.
  • Carry a 60*60*10 aluminum heat sink, 6*1W external resistance sensor. A more powerful driver current.
  • Limit input voltage: 45v.
  • Thermal shut down (TSD) protection,Under voltage lock out (UVLO) protection, Over-current detection (ISD) protection.
Stepper Motor Driver 2.3 (using A3982) Yes US 2 A 1/2 Listed for comparison.
EasyDriver (using A3967) Yes US 0.75 A 1/8 Slightly underpowered compared to other drivers, at only 750 mA/phase. bothacker uses EasyDriver[1], and reports that it has plenty sufficient power for Mendel. Recommended.
Pololu stepper driver board Yes US 2 A 1/16 Can get very warm; active fan cooling or passive small heatsink is needed above ~0.5 A. Recommended.
... ay.com/autohec 4 Axis Stepper Motor Driver Controller (using A3977) Yes US 2.5 A 1/8 4 stepper drivers on a single board.
DIY CNC No GB 2.5 A 1/8 Can drive 1 stepper; discount when buying several.
Arduino Motor Shield No US 0.6 A ? Requires Arduino as controller. Can drive 2 servos, 4 DC, or 2 (bipolar or unipolar) steppers. Website notes that you can increase the max current by piggy-backing (soldering a chip onto a chip) another L293D chip on top of the first (and another one on top of that)
... ay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=4+axis+TB6560&_sacat=See-All-Categories TB6560AHQ based No GB/PRC 1.5 - 3 A 1, 1/2, 1/8, 1/16 Can drive 3 to 5 steppers depending on model; read more.
Stepper Driver 2.3 Clone by kymberlyaandrus Yes US 2 A 1/2 Same schematic but physically smaller than the original version. The trim pot doesn't have a start/end point so adjusting the current can be more difficult than other boards. The terminal blocks are nice because they don't require making special connectors.
Gecko Drive Yes US 3.5 A 1/10 (only) Can drive 4 steppers
Nanotec SMC11 Yes GER 1.4 A 1/16 with cooling until 2.5 A
LiniStepper by Roman Black no US 3 A 1/18 and "stepless" Open Source: Circuit Diagram, PCB (Board) Layout, and PIC Software all available.
Tri Duino Stepper ??? ??? ??? ??? Open Source
A3979breakout ??? ??? ??? ??? ???
grblshield No US 2.5 1/8 3 axis controller plugs onto Arduino Uno or similar
Developments
PiBot Box will put on sale recently. It is made of steel plate, can contain 1 to 6 driver.
Enjoy!
