Pick and Place ToolHead
Revision as of 17:59, 24 March 2011 by ErikDeBruijn (talk | contribs) (Pick-n-Place related)
Release status: Experimental
A new toolhead to allow RepRaps to manipulate surface mount components.
unknown
You might also want to look at PickandPlaceTool. Perhaps some or all of that page should be merged into this page. (Discuss)
This new toolhead allow RepRap to manipulate surface mount components. This is one small step towards enabling a RepRap to produce its own required PCBs. See Automated Circuitry Making for other steps towards that goal (milling head, solder paste dispenser, etc.)
How it works
a small vacuum pump creates suction in the blunt tip needle to pick up SMT components and the gear motor rotates the component into the proper position.
Materials
  • 6 20 mm M3 cap screws
  • 3 35 mm M3 cap screws
  • 1 10 mm M2 screw, or whatever screw will couple with the shaft on the GM3 gear motor
  • 1 18 gauge blunt tip dispenser needle
  • 1 magnetic rotary encoder and magnet retrofitted GM3 gear motor
  • 1 meter of 4 mm diameter aquarium tubing $0.43
  • a low vacuum pump, possibly a reversed aquarium air pump
Instructions
  1. connect the part named pnpdisk2 to the motor drive shaft
  2. stick the 4 mm aquarium tubing into the blunt tip dispenser needle and put this into the part called pnpdisk1
  3. attach pnpdisk1 to pnpdisk2 with the 20 mm M3 cap screws
  4. attach the magnetic rotary encoder to the part called pnpclamp with 20 mm M3 cap screws
  5. attach gear motor to clamp with 35 mm M3 cap screws
  6. attach clamp to x carriage
Further reading
  • "Pick and Place Project": designing an open-source pick and place machine[1][2][3][4].
