Template:CupCakeStrap
CupCakeStrap
Release status: unknown
Description |
Makerbot Cupcake as RepStrap
License |
Author |
Contributors |
Based-on |
Categories |
CAD Models |
External Link |
This is an in-progress build
This project is made 90% from kludge and improv hackery. It is not meant as a tutorial or even a rough guide so much as it is intended as inspiration.
CupCakeStrap Basics:
Nothing is promised to apply to your material situation
The CupCakeStrap is the concept of using the Makerbot Cupcake design base as a bootstrapping platform for a RepRap.
Essentially, a very cheap printer which will print out RepRap parts and then donate its electronics, motors, and even metal hardware.
So, I bet you're asking "What's the attraction to building a Cupcake, with its smaller print area, high price, and odd naming?"
Well, first off, it's the cutest of printing machines. Secondly, if it's not going to be purchased outright from Makerbot, it's really not very expensive at all. I'm not trying to say that the machines Makerbot sells are not excellent or are over priced, but the draw to make one from scratch is pretty strong.
CupCake Price Breakdown:
The makerbot's $750 base price is just for:
laser-cut plywood and laser-cut plastic = $200
3 NEMA 17 stepper motors and one big gearmotor = $75
Nichrome wire, PTFE tube, and a milled barrel and nozzle ~ $30
The reprap-derived electronics for controlling it. = $200
Nuts, bolts, bearings, pulleys, metal rods and brushings and assorted metal parts, including some magnets ~ $250
1lb of ABS ~ $20
Belts = $???
M3 and M8 Allen keys = $???
You should note that those prices are what you would pay Makerbot for the individual items (as of march 31st), and do not properly represent their market value.
It also totals more than $750.
The "deluxe" version adds $200 for the following:
Some more laser cut plastic
An ATX powersupply (like in a desktop computer)
A USB to TTL cable to interface with it
The cables that you need to connect the machine up it its own parts
5lbs more ABS
Hex keys, wrenches, and some metal parts
An SD card.
Now, that's a respectable list, and probably worth every penny to someone who does not already have any of those items.
However, if you are in a position to use or borrow any of those things, the price becomes a lot less appetizing.
Thus, it is a good idea to treat the machine as a RepStrap, and not worry about building an exact clone of the Master CupCake in whose likeness all other CupCakes are forged.
Related Projects
Text text text text New Example. Another Example text text text text text text text text.
Files and Parts
Sub Assemblies and Related
Text text text text Example/SubAssembly and Related Example text text text text text text text text text text text text text text text.
Files and Parts
Downloads
Photos and Drawings
Links can be put in captions.
More Examples
Huge Image
Really big example images with lots of descriptive text are a fun part of documentation.
Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text.
May contain scaffolding.
This page may contain "scaffolding" - mediawiki text from the
Example page that may not need to be there.
It may help to delete the parts that you don't need.
(more details)
