Plasma Cutter
Revision as of 00:42, 27 December 2019 by Eagletec (talk | contribs) (Plasma Cutter)
CNC Plasma Cutter
plasma table EagleTec EA-PL1530 is a standard version model; with cutting size 1500x3000mm, convert into English unit is 5x10 feet. Drawers on the side of the machine base are designed for cleaning the slag easily. This computer plasma cutter is a good cut solution for metal plates or sheet metal within 1500x3000mm size range.
Plasma Power: the affordable cnc plasma cutter EA-PL1530 is equipped with 105amp Hypertherm plasma generator. Suggested max. cutting thickness is 18mm (refers to quality cut on machine here).
Plasma Torch Height Control System: standard version includes the arc voltage torch height controller which ensures quality cut even on uneven metal sheets.
Linear Guide: standard version is round type; square type is as optional configuration.
Environmentally friendly design: with fans for dust and smoke moving and drawers for cleaning slag easily.
Plasma Metal Cutting Machine CNC Controller: adopts Starfire which is specially for plasma cutting purpose, with LED display, English menu; the system also has a pattern library inside, just select the pattern you want and input several machining parameters, the cnc plasma cutter will start work for you.
Top 10 CNC Plasma Cutting Table
