PolygonDelta1070
Revision as of 04:58, 1 December 2015 by Billyzelsnack (talk | contribs)
PolygonDelta1070 Documentation
Polygon Delta 1070
Extrusion and lasercut hub and spoke scalable linear delta
The PolygonDelta1070 is a linear delta robot 3D printer designed around the beautiful Misumi 1070 flat extrusions with laser cutting as the manufacturing process for nearly all of the non-off-the-shelf parts.
December 2015 release
Laser Files
File:Polygondelta1070 laser dec2015.pdf
Laser Materials
3/32" Delrin (Columns A,B*3,C)
1/8" Delrin (Columns D,E,F)
3mm Acrylic (Columns G,H)
1/32" Delrin (Columns I)
1/16" Delrin (Columns J)
Hardware BOM
-- Tower HW times 3
2 M2x8 socket
4 M3x6 low profile socket
6 M3x6 dome black
11 M3x8 dome black
4 M3x10 dome/countersink black
3 M3x22 socket
3 M3 t-slot nut
2 M5x5/6 cup set screw black
1 M5x8/6 dome black
8 M5x10 dome black
1 M5x18 socket black
9 M5 t-slot nut
2 M5 large diameter washer
1 M5 small diameter washer
4 corner bracket
2 11x5x5 bearing
3 12.7x0.1875x0.12" standoff
1 sorbothane bumper
1 microswitch
-- Hub HW times 2
6 M5 t-slot nut
6 M5x8 dome black
1 M3x10 dome black
9 M3x6 dome black
-- Ebox HW
4 M2.5x6 socket
7 M3x6 dome
-- V6/Lite6/Volcano Effector HW
3 M2x10 dome
8 M2.5x6 socket
6 M3x5 dome
12 M3x8 dome
2 M3x12/14 dome
6 M5x5 setscrew ferrous
-- Filament Drive HW
5 M5x10 spacer
4 M3x8 dome
1 MK8 drive pulley
16 M3x16 dome
4 M3x10 dome
2 8-32" hex nut
1 10x5x4 bearing
(Further text, build files, and documentation to follow.)
