PolygonDelta1070
Revision as of 01:01, 3 December 2015 by Billyzelsnack (talk | contribs) (Sizing Examples)
PolygonDelta1070 Documentation
Polygon Delta 1070
Extrusion and lasercut hub and spoke scalable linear delta
The PolygonDelta1070 is a linear delta robot 3D printer designed around the beautiful Misumi 1070 flat extrusions with laser cutting as the manufacturing process for nearly all of the non-off-the-shelf parts.
Release December 2015
Laser files
File:Polygondelta1070 laser dec2015.pdf
Laser Materials
3/32" Delrin (Columns A,B*3,C)
1/8" Delrin (Columns D,E,F)
3mm Acrylic (Columns G,H)
1/32" Delrin (Columns I)
1/16" Delrin (Columns J)
Hardware BOM
File:Polygon delta BOM HW 2015dec.txt
Extrusions
The design uses Misumi 1070 Flat Extrusion for structure and linear motion guides.
HFSQN4-1070 [1]
Sizing Examples
The Polygon Delta is designed to be be easily scalable within reasonable limits. To increase the build diameter of the machine you only need to increase the rod lengths, spoke extrusion lengths, bowden tube length, and build platform diameter. To increase the height of the machine you only need to increase the tower extrusion lengths, bowden tube length, and belt lengths.
Build diameter of 6" and build height of 6"
  • 100mm extrusion spoke lengths
  • 170mm rod length
  • 6" platform
  • 470mm extrusion tower lengths
Build diameter of 8" and build height of 8"
  • 125mm extrusion spoke lengths
  • 220mm rod length
  • 8" platform
  • 570mm extrusion tower lengths
Build diameter of 10" and build height of 10"
  • 150mm extrusion spoke lengths
  • 270mm rod length
  • 10" platform
  • 670mm extrusion tower lengths
Build diameter of 12" and build height of 12"
  • 175mm extrusion spoke lengths
  • 320mm rod length
  • 12" platform
  • 770mm extrusion tower lengths
Misumi Ordering Example
(Further text, build files, and documentation to follow.)
