PortaPrusa Build Manual
PortaPrusa Documentation
About Build Manual
This is my personal build log, I will be posting regular updates as I make progress.
Still To Be Printed Parts
The Repo for the PortaPrusa contains all of the STLs you need in order to make the printer.
The following is a list of what still needs to be printed:
Quantity | STL file | Comments | Picture |
1 | Bed-Clamp.stl |
Done
These are Completed Prints
Laser Cut Parts
These Parts need to be laser cut.
- The Wooden box is made from '1/4 in' (.2 in) or 5mm sanded ply.
- You will need a 2ft x 3ft board to do it all. (usually sold in 4 ft sections)
- There is also a Piece made from acrylic, but I haven't designed it yet, so that will have to be put on hold.
Laser Cut Parts
You can find the dxfs on the Github
Quantity | Description | Comments |
5mm Wood | ||
1 | Front.dxf | The big sheet |
1 | Back.dxf | The other big sheet |
2 | Left.dxf | Side of box |
2 | Right.dxf | Side of box |
1 | Top.dxf | Top of box |
1 | Bottom.dxf | Bottom of box |
Whole-Frame.dxf | All of it! | |
Acrylic | ||
1 | bedMount.dxf | Goes under heated bed |
Other Parts..
Here are some of the electronics I'm using.
- Extruder - I'm not sure what this extruder is called, will try to update when I figure that out.
- Controller - This printrboard was made by geeetech, I got it on sale for a great price! :)
- Motors - (still need to take a picture) I'm using 5 compact Nema 17 stepper motors. Most Nema17s are pretty similar, but there are some differences, mainly in the wires.
