PortaPrusa Build Manual
Revision as of 20:53, 19 May 2014 by Cubedparadox (talk | contribs) (Laser Cut Parts)
PortaPrusa Documentation
About Build Manual
This is my personal build log, I will be posting regular updates as I make progress.
Still To Be Printed Parts
The Repo for the PortaPrusa contains all of the STLs you need in order to make the printer.
The following is a list of what still needs to be printed:
Quantity STL file Comments Picture
Done
These are Completed Prints
4 M8-Mount.stl Done! 20140519 180541.jpg20140519 181032.jpg20140519 181624.jpg20140519 181842.jpg
4 M4-Mount.stl Done! 20140519 180556.jpg20140519 180635.jpg20140519 180710.jpg20140519 180722.jpg
Laser Cut Parts
These Parts need to be laser cut.
  • The Wooden box is made from '1/4 in' (.2 in) or 5mm sanded ply.
  • You will need a 2ft x 3ft board to do it all. (usually sold in 4 ft sections)
  • There is also a Piece made from acrylic, but I haven't designed it yet, so that will have to be put on hold.
Quantity Description Comments
5mm Wood
1 Front.dxf The big sheet
1 Back.dxf The other big sheet
2 Left.dxf Side of box
2 Right.dxf Side of box
1 Top.dxf Top of box
1 Bottom.dxf Bottom of box
Whole-Frame.dxf All of it!
Acrylic
1 bedMount.dxf Goes under heated bed
Other Parts..
Here are some of the electronics I'm using.
  • Extruder - 20140516 172310.jpg I'm not sure what this extruder is called, will try to update when I figure that out.
  • Controller - 20140516 172422.jpg This printrboard was made by geeetech, I got it on sale for a great price! :)
  • Motors - (still need to take a picture) I'm using 5 compact Nema 17 stepper motors. Most Nema17s are pretty similar, but there are some differences, mainly in the wires.
