PortaPrusa Build Manual
Revision as of 11:35, 31 May 2014 by Cubedparadox (talk | contribs) (Hardware)
PortaPrusa Documentation
About Build Manual
This is my personal build log, I will be posting regular updates as I make progress.
Still To Be Printed Parts
There are a few parts that I am considering making, such as pla bushings and a bar to lock the box open, but all existing files have been printed :)
Printed Parts
These are Completed Prints
Quantity STL file Comments Picture
4 M8-Mount.stl Done! 20140519 180541.jpg20140519 181032.jpg20140519 181624.jpg20140519 181842.jpg
4 M4-Mount.stl Done! 20140519 180556.jpg20140519 180635.jpg20140519 180710.jpg20140519 180722.jpg
Laser Cut Parts
These Parts need to be laser cut.
  • The Wooden box is made from '1/4 in' (.2 in) or 5mm sanded ply.
  • You will need a 2ft x 3ft board to do it all. (usually sold in 4 ft sections)
  • There is also a Piece made from acrylic, but I haven't designed it yet, so that will have to be put on hold.
5mm Wood
Acrylic
1 bedMount.dxf Goes under heated bed
Hardware
Electronics
Here are some of the electronics I'm using.
  • Extruder - 20140516 172310.jpg I'm not sure what this extruder is called, will try to update when I figure that out.
  • Controller - 20140516 172422.jpg This printrboard was made by geeetech, I got it on sale for a great price! :)
  • Motors - 20140521 173426.jpg I'm using 5 compact Nema 17 stepper motors. Most Nema17s are pretty similar, but there are some differences, mainly in the wires.
Building Guide
Step One
The first thing you need to do is insert the linear bearings into their respective 3d parts. 20140522 180005.jpg
Step Two
We will now mount the Z-motors to their mounts, and attach those to the frame. Vitamins - 3x M3 bolts, nuts Note - my motors came with bolts, yours may not. 20140525 211147.jpg 20140525 212035.jpg
Step Three
It's time to assemble the X carriage. Note - I had to drill out some holes for the smooth rods to fit. 20140525 204354.jpg
Step Four
Now we will put together the sliding mechanism. Vitamins - 8x M3 bolts, nuts; a couple bolts and washers for pivots. 20140526 183540.jpg
