PortaPrusa Build Manual
Revision as of 17:00, 12 April 2015 by Glenn (talk | contribs) (+cat)
PortaPrusa Documentation
About Build Manual
This is my personal build log, I will be posting regular updates as I make progress. Update: I just redesigned the printer, let's start over!
Still To Be Printed Parts
There are a few parts that I am considering making, such as pla bushings and a bar to lock the box open, but all existing files have been printed :)
Printed Parts
These are Completed Prints
Quantity STL file Comments Picture
Laser Cut Parts
These Parts need to be laser cut.
  • The Printer is made from '1/4 in' (.2 in) or 5mm sanded ply.
  • You will need a 2ft x 3ft board to do it all. (usually sold in 4 ft sections)
The parts are contained in PortaPrusa_V3_Pack.dxf on the repo
Hardware
Electronics
Here are some of the electronics I'm using.
  • Extruder - 20140516 172310.jpg I'm not sure what this extruder is called, will try to update when I figure that out.
  • Controller - 20140516 172422.jpg This printrboard was made by geeetech, I got it on sale for a great price! :)
  • Motors - 20140521 173426.jpg I'm using 5 compact Nema 17 stepper motors. Most Nema17s are pretty similar, but there are some differences, mainly in the wires.
==Building Guide== Ignore - out of date
Step One
The first thing you need to do is insert the linear bearings into their respective 3d parts.
Step Two
We will now mount the Z-motors to their mounts, and attach those to the frame.
Vitamins - 3x M3 bolts, nuts
Note - my motors came with bolts, yours may not.
Step Three
It's time to assemble the X carriage.
Note - I had to drill out some holes for the smooth rods to fit.
Step Four
Now we will put together the sliding mechanism.
Vitamins - 8x M3 bolts, nuts; a couple bolts and washers for pivots.
