Portable Skeinforge
Revision as of 11:23, 3 April 2011 by Spacexula (talk | contribs)
Portable Skeinforge
Release status: Experimental
A portable version of Skeinforge
GNU Affero General Public License
About
Thumb drive executable Skeinforge. You do not need to have Python installed to run this, so it can be run from any computer, even those that you do not have a access level high enough to install Python with (Yea! for skeinforgeing at work)
Why use it?
This is a compiled version of Skeinforge which allows you some functionalities not avialable in standard Skeinforge 40:
-Able to run in Windows form an .exe file -The settings are saved into the same directory that you uncompress the file, so it allows you to run as many different versions of skeinforge as you want -Python is compiled into the .exe so you can run this skienforge on a machine without Python installed, which makes use of skeinforge at public computers much easier.
The Future
See Also
