PrintItStickItCutit
Revision as of 23:05, 16 December 2010 by Bodgeit (talk | contribs) (Created page with 'DIY Build Method. Print out the PDF DXF drawings to scale on a Printer. Laser printer or Inkjet printer. Cut out the parts including the outlines or if neded stick multilpe pri…')
DIY Build Method.
Cut out the parts including the outlines or if neded stick multilpe prints together to create a full part image.
This method works best using MDF as it is easy to cut with a craft knife, chisel, hacksaw, dremel.
Select your MDF sheet stick the outline you want to make onto it using a Glue stick.
Drill all the required holes.
Now start cutting out the shape using a craft knif or any tool you prefer.
Make your self a Cupstrap or BasicMendel or Huxley Seedling using this method.
