Print Troubleshooting Pictorial Guide
Revision as of 15:20, 28 December 2013 by Funny bananas (talk | contribs) (fixed sentence structure)
[>>still populating data 9/1/2013- You are welcome to help. see [1]<<
This guide assumes a basically properly built and calibrated printer Main_Page. This guide is not intended as a design guide, but more as an operational troubleshooting guide. If you have not read through and attempted a complete calibration, see the REPRAP wiki for Calibration instructions. Some common calibration issues as well as common build related issues however are discussed.
(Please note: This guide is for identified and resolved issues only. The more common the issue, the better. No questions or open issues belong here, go to the forums for interactive help (look to your left in the links column). Use clear and concise language, only 6 pics or entries per issue.)
The following categories are used to help identify the print issue by either print defects or by cause (if known). The print defects will point to identified causes and branch into individual examples and solutions:
CAUSES:
Material Feed
Excessive
Material Feed, Excessive
Problem Common Cause Correction Forum Link
Wall thicknesses are coming out too thick, objects have outside dimensions consistently slightly too large and holes are slightly too small. Slicer software settings for perimeter widths are slightly too high. Reduce flow rate setting for perimeters. Skeinforge has these settings available to change. [2]
Insufficient
Intermittent
Material Handling or Source
Material Contamination
Material Handling, Material Contamination 01
Tiny filament width holes on print sides. Steam blow-outs or bubbles from water absorbed from the humidity in the air into the raw filament during storage prior to printing. PLA is more susceptible to this as it has an affinity for water. Proper handling of filament to reduce exposure to humidity. [3]
</tr>
Material Handling, Material Contamination 02
Extruder jams for no apparent reason. After the extruder hot section has been disassembled and cleaned out, it is rare to find the particle that was blocking the nozzle. Foreign particles may be visible in transparent filaments and may be accompanied by gas bubbles. Test for condition: (may damage nozzle) while extruder hot, insert a drill bit into the nozzle. If ooze occurs then stops again after drill bit is removed, a foreign particle may be in melt chamber. Particulate inclusions in raw filament as purchased from source. Found in cheap filament (Chinese mfr) noted in PLA from Esun. Use quality filament from known sources. [4]
Indications of abrasion may be noticed internally in the thermal isolator of the hot end with the lines of abrasion in the direction of filament feed when disassembled. Print may show indications of intermittent plugging and unplugging of nozzle. Low melting point metal (likely solder) ball noted in ABS (mfr not determined).This may indicate sub-orifice size foreign particles passing through extruder.Use quality filament from known sources.[5]
</td>
Material Handling, Material Contamination 03
Popping sound from nozzle like air bubbles under pressure or popcorn popping. Causing blowouts and missing plastic in part buildup. Filament (ABS in this case) contains air bubbles or voids from manufacturing process. Examine your filament for indications of this manufacturing defect. Use quality filament from known sources [6]
Extruding Temperature
Too hot
Too cold
Clogged Extruder
</tr>
Clogged Extruder
Extruder jambs at normal temperatures in the hotend's thermal isolator bore. Excessive thermal isolator bore diameter allowing too much molten plastic back flow too far up isolator bore causing jamb when it solidifies. Replace thermal isolator or isolator sleeve leaving .1 to .2mm only above filament diameter clearance for filament thermal expansion. (ex. 3.175mm for 3mm filament, filament is actually 2.9 +/-.1mm) [7]
Extruder frequently becomes jammed, but works fine briefly after clearing the jamThermal isolator or cold end getting too hotPut a small fan on the hot end to cool the top.
Leaving printer extruder heated up for 20 minutes or more without extruding, the extruder jams.Insufficient length of thermal isolator or insufficient cooling of thermal isolator or cold end of extruder. Heat travels up the filament and may cause filament distortion above thermal isolator if cooling is insufficient.Lengthen thermal isolator or add a fan to thermal isolator or cold end of extruder and filament. Or limit extruder hot time and/or extrude 10mm every 10 minutes.[8]
</td>
Bed Adherence
Insufficient
</tr>
Bed Adherence insufficient
Prints do not adhere to build platform. Print head too high to push plastic against build platform Change height settings to no greater than nozzle diameter above bed, calibrate bottom stop, level build platform
Tall parts tend to detach before build is complete.Too low of contact area for the height or too low adhesion.Select to use a raft with a larger footprint to aid adhesion, or use skirt with zero offset to increase base area.[9]
</td>
Corner Lift
Outside corners lift from build surface as build progresses. Differential cooling of printed object. Select to print a perimeter skirt in Skeinforge or brim in slic3r with a substantial height. The tall skirt/brim acts like a shell which holds in the heat and reduces corner lift. [10]
Excessive
</tr>
Bed Adherence Excessive
Printed parts adhere to the print bed too aggressively. Shown ABS printed on heated PC (polycarbonate) sheet. Bed material selection needs to be compatible with material printed and temperature used. PLA on heated glass works well as a build surface, Blue painters tape unheated works well for PLA, ABS on heated bed with Kapton tape works well, ABS on heated bed with PET tape works well. See build forum for examples and suggestions. [11]
Printed parts adhere too aggressively. Shown ABS on heated glass took chip out of glass.ABS may adhere too aggressively on uncoated glass.Use Kapton or PET tape on glass for ABS. See build forum for examples and suggestions.[12]
</td>
Print Speed
Too Fast
Too Slow
Calibration
Circularity
Non-circular Holes
Holes come out compressed in one direction (X or Y). Loose drive train on the deformed axis. Inspect the discrepant axis drive train for excessive slack in belt, loose gears on shafts or gear play then tighten as appropriate. [13]
scale
Skipping Steps
Controller Overpowered
Skipping Steps, Controller Overpowered
printer head fails to keep its position and prints successive layers offset from lower layers. Frequently called skipping steps, joggle or offsetting. Several possible causes- This first one (red coin holder) was stepper controllers had their potentiometers (pots) adjusted too high (clockwise), causing overheating of stepper controller and causing a short controller reset to cool down (fraction of a second each time). This high setting may also produce hotter stepper motors. Reduce pot setting (current) by carefully turning pot counter-clockwise. [14]
Controller Underpowered
Part Temperature
Too hot
Part Temperature, too hot 01
Prints warp at height Part temperature builds up as part is built Change settings to turn off or down temp of heated build platform after base layers are complete. Ex: with heat on all through print and off upon print start (starting at full temp but cooling as it goes) (pic01).  ?
Too cold
Part Temperature, Too Cold 01
Part warping and delamination as print progresses. Part cools too fast causing contration especially in ABS which has a higher glass transition temp of ~140C. Print perimeter surrounding skirt full height of part to keep the heat in. [15]
PRINT DEFECTS:
Surface Defects
Pitting/Holes
#Material Contamination
Small Single Filament
Large Area of Filament
Jagged/Waviness
Jagged Edges
Jagged edges in some locations adjacent to short edgefill segments. Harmonic frequencies may be overloading the rigidity of the mechanical system. Reduce frequency of moves by some means. Increasing the minimum length setting is a global way to reduce move induced vibration. Also reducing move speed or acceleration may reduce these issues. [16]
Solidity of Surface
Top Layers Not Solid
Not all areas which are external surfaces have the same fully solid surfaces. Also related is the alternate condition of lumpy walls and ridges on the top surface. See bottom of rectangular well in pic. Skeinforge setting "Infill Interior Density over Exterior Density" ratio, which defaults to 0.9 may cause the lack of solidity and compensating with other settings may produce the latter effects. In Skeinforge set Infill Interior Density over Exterior Density to 1.0. (This setting has been removed in later versions of Skeinforge.[17]) [18]
Strings
Blobs
Fineness of Detail
Filaments not Touching
Infill Gaps
Infill gaps to perimeter
Infill gaps to perimeter occur on one side of the part. Excessive force required to pull filament from its bin or reel. Rework filament retrieval system to reduce friction or pull load to printer. [19]
Infill gaps to perimeter 02
Gaps occur between infill and perimeters especially on small details. Some slicing software is more prone to produce infill gaps to perimeters. If you have tried adjusting the settings available in your slicer without success and are tempted to change what should be constant parameters (like nozzle diameter etc...), you may want to try another slicing program to see if the problem is slicer dependant. There are many slicing programs available. http://forums.reprap.org/read.php?262,237444
Body Defects
Hole Size
Holes Undersized
Holes defined in solid model print smaller in diameter than modeled. Several factors are likely adding up to the result and include faceting error, segment pausing, arc shrinkage and corner cutting. It has been demonstrated that the maximum number of vertices you can have before the hole shrinks is twice the hole size in mm. In other words, a larger # polygon circle defining a hole does not necessarily make for a more precise hole when printed. For 1mm and under it is suggested to use 3 sides (triangle). [20]
Bridging Failure
Degenerating Bridging
The ability to bridge well is deteriorating over time. Nozzle walls can build up deposits which cause additional restriction within the nozzle after months of use. To verify this is the cause, measure the extruded filament diameter and verify that it is smaller than originally measured during calibration. Due to die swell, extruded filament diameter is usually not identical to nozzle hole diameter. With the nozzle heated up carefully ream out nozzle orifice with original size drill bit. [21]
Warping
#Part Temperature
Stepping/Offsetting
#Skipping Steps, Controller Overpowered
Interlayer Delamination
#Part Temperature
Failure at Height
#Part Temperature
Overall Disaster
Computer Freeze
While printing from a computer any type of computer freeze up or communication failure may cause 3D printer damage or worse- a fire. Although I have only heard of one 3D printer catching on fire, with the electricity and heat there is a hazardous potential. Computer system automatic updates. Set automatic updates to off. The above picture had automatic updates turned off, but Microsoft overrode that and installed them anyway. [22]
Machine Heat Effects
Overheating the machine itself can cause damage to RP (plastic) parts. Heat radiation and convection caused x-stage damage over months of heavy use. Heat shield and or fan cooling of stage. [23]
If you are not certain about having correctly calibrated your printer, verify that it is calibrated first as that is the first step. See Calibration. Verify you also calibrated your extruder. Then verify your extruder zero height (endstop position) above your print bed is appropriately set.
