PrintrbotMetalSimpleDaughterboardtoControllerCable
This page is for those that have printrbot boards g2 and need help wiring to other electronics from ramps to printrbot f6 boards.
-- read special notes section -- if not using f5 or f6 boards.
*** this is a draft page until this comment removed ***
contents.....
[why]
[who invented the machine used]
[goal is to make a cable to interface machine]
[why this page]
[what is my solution?]
[different end connectors and names of parts needed, including printable ones]
[how to start process of designing replacement cable]
[special notes]
[this is a draft page until this is removed] this is here until spelling and objective views makes it sense.
[why]
the company is now no longer in service, and i am unable to find any support anywhere else that truly supports them.
i want to personally thank Brook Drumm for his contribution to reprap, and for his work in 3d printing. it is a hard business with extremely dynamic changes.
i plan on making a cable that interfaces the beautifully constructed mechanics of the printrbot metal pro and the designed extruder board to the more standard f5 and f6 electronics or even any ramps or other electronics with ease and less frustration.
[why this page]
I am helping out at a maker space to make myself useful. this maker space is relying on several printrbot simple metal pro's that are in need of maintenance. these boards use advanced controllers, that in theory are better than 8 bit Reprap are no longer supported and many modern features that people use and or understand are not implemented, and knowledge of these g2 boards seems to be fading. for reasons of available knowledge experience, and the ability to switch boards out for future proofing. these printers are built to last mechanically, even though in my opinion electrically there is some work.
a cable connector to the daughter board of printerbot metal simple pro, that one side plugs into the extruder daughter board and the electronics it houses, and the other end having labeled pins, and correct connectors to hook up to standard reprap electronics. the connectors ideally will be labelled and pinned with the correct type of connectors to reduce errors during hookup. the idea is to make board replacement faster, and allow an affordable and timely transition over to reprap electronics.
may 29.2019 i found conflicting information on the web and no support info from printrbot.com as of the time of this writing the web sight has no documentation. i used a volt meter available to me by the maker space to check pin connections when device was disconnected and off. i will need to do a digital drawing of pin out but for now i have this image that i hope is helpful to people that have the printrbot simple metal pro
may 29,2019 8:30pm found a web page with some design specs for metal pro here https://www.brookdrumm.com/
this information below is my draft drawing. not 100% tested yet.
MALE CONNECTOR END THAT GOES TO CABLE
here is an image of current prototype. it plugs into the 26 pin cable that goes to daughterboard on extruder. the individual free pins will be replaced with labeled pins and connectors to the ones that are typically available for general reprap electronics. having the proper end connectors should reduce error rate and make it easy to change out board, but leave the daughter board in. allowing only the main board to be replaced.
i will attempt to make pins ends 3d printable and provide files for them, and make casings that could be 3d printed.
it is too much work to solder connections, so us bare pressure pin connectors,
if using ones with plastic outer sleeves they need to be removed. push down on the pins,
and glue them into place. in image it is a mold made for pvc glue. i would assume later
versions to just use resin. i will also post the mold here used when it works completely.
This cable connector also requires molex connectors of different types and styles to avoid error when plugging parts in. some of these wires, will have a dummy lead, because of a shared common gnd.
here is a list of connector types needed, and part names for them
4 pin connector for stepper e axis
4 pin connector for stepper y axis
2 pint fan connector ->
2 pin led connector ->
2 pin thermistor connector ->
2 pin fan connector
3 pin probe connector (may go down to 2, because of common gnd)
3 pin y axis home switch (needs resistors on both leads of 50 ohms built into wire)
2 pin heater connector
2 pins blower fan pins
[special notes] if not using an f5 or f6 board the end stop wiring could be different, so i will include a 50 ohm resistor in my final design to prevent damage while troubleshooting.
this is why i will leave a connector on end stops that has 2 wires, but not a 3 pin connector. if 50 ohm resistor is not included and it is wired up, a board could short out otherwise. 50ohm resistor is added for safety.
here are pinouts of each homing pins
printrbot f5 and f6 boards
ramps shield boards
[for probe]
this needs to be wired properly to avoid tool head crash, and to avoid probe damage. from my understanding so far the wiring is this:
[blue] to signal z axis pin
[black] to gnd pin
[red] to pos 5v pin
