Printrun
Printrun is a set of G-code sending applications, written by Kliment. It consists of printcore (dumb G-code sender), pronsole (featured command line G-code sender), pronterface (featured G-code sender with graphical user interface), and a small collection of helpful scripts. Together with skeinforge or Slic3r they form a powerful printing toolchain.
Installation
GNU/Linux & Distros
Dependencies
Before installing Printrun, make sure to install a few required libraries for both pronterface and skeinforge. These are just informational links, the install instructions individual linux distributions are below.
Depending on your GNU/Linux distro, this can be done in several ways. The following is executed through the Terminal, often found under "Applications -> Accessories -> Terminal":
Debian
You can run Printrun directly from source, as there are no (official) packages available yet. Fetch and install the dependencies using:
sudo apt-get install python-serial python-wxgtk2.8 python-pyglet
There are experimental packages for Debian (squeeze wheezy):
sudo echo "deb http://apt.ulrichard.ch/ squeeze main contrib non-free" >> /etc/apt/sources.list sudo apt-get update sudo apt-get install printrun-gui
Fedora
Printrun is in official Fedora repositories starting with Fedora 17.
sudo yum install printrun # for the whole package, or: sudo yum install pronsole # or plater or pronterface
Any problems with these packages, report to Bugzilla. Don't forget to add your user to the dialout group.
If you have older version of Fedora or you just don't want to use the packages, install dependencies and follow instructions below.
sudo yum install git pyserial wxPython tkinter
Ubuntu
sudo apt-get install python python-serial python-wxgtk2.8 python-tk git-core
There are also experimental packages for Ubuntu (maverick natty oneiric precise):
sudo apt-add-repository ppa:richi-paraeasy/ppa sudo apt-get update sudo apt-get install pronterface
Note: The previous package, 'printrun-gui' is currently broken on Ubuntu 'precise', but may work on previous Ubuntu releases. Both are in the same repository.
Install & update script
This script gives somehow the impression Printrun has to go through a complex installation. The most simple case is to meet the prerequisites above, then grab a copy from Github and run it with python pronterface.py
right where you downloaded it.
For a more comfortable installation, you should install pronterface first, then skeinforge inside your pronterface installation directory.
This albeit little dirty but handy script does that for you! (N.B it can also be used as a update script. Be sure to put your .stl-files etc outside of your Printrun directory)
BASEDIR="$HOME/RepRap" # edit this is you don't want it installed in your home directory PRINTRUNDIR="$BASEDIR/Printrun" # Defines where the 'Printrun' directory is located. But of course # you can change this to say: "$HOME/Documents/Create/RepRap/Printrun". SKEINFORGEDIR="$PRINTRUNDIR/skeinforge" #Defines where the 'skeinforge' directory is located in the # 'Printrun' directory is located. SKEINFORGEBASEURL="http://fabmetheus.crsndoo.com/files/" SKEINFORGEFILENAME="50_reprap_python_beanshell.zip" cd $BASEDIR # Change directory to the executing users home directory. echo "Removing existing Printrun directory..." #Script being polite towards the user. rm -rf $PRINTRUNDIR # Removes the defined Printrun directory and _everything_ that resides # in and beneath its directory tree. echo "Cloning Printrun..." # Script being polite towards the user. git clone https://github.com/kliment/Printrun.git # See also: http://help.github.com/linux-set-up-git/ echo "Grabbing skeinforge..." # Script being polite towards the user. wget -P /tmp $SKEINFORGEBASEURL$SKEINFORGEFILENAME # Uses good ol' wget for downloading skeinforge. echo "Unzipping skeinforge into Printrun directory..." # Script being polite towards the user. unzip -d $SKEINFORGEDIR /tmp/$SKEINFORGEFILENAME # unzips the grabbed zip to ones defined skeinforge dir. echo "Symlinking skeinforge inside Printrun directory..." #Script being polite towards the user. ln -s $SKEINFORGEDIR/* $PRINTRUNDIR/ # Script makes a symbolic link. echo "Cleaning up temporary installation files..." #Script being polite towards the user. rm -rf /tmp/$SKEINFORGEFILENAME # Removes tmp files.
Open a terminal window and copy the script above.
Create a directory in your Home directory named RepRap
Open nano by typing 'nano' in the windows prompt and hit return.
Save the script in a file named 'PrintrunUpdate', make any adjustments if you want/need to. (If a new software version comes out, you will have to change the 50_ (which is the current version since March 2012) into the correct version number).
Most likely you need to use the following:
chmod +x PrintrunUpdate
This will set permission to allow you to execute the script.
If you were to do this in your filemanager (Nautilus etc) it will ask you if you want to run this script.
NOTE: There is an error installing on ubuntu and using this script. One method of install results in a link in the applications menu, which links to pronterface fils in usr/bin/ and the file in usr/share. Another method results in files in the users' home directory. Which is the recommended method and proper location to install? Neither method leads to successful installation at this point.
Mac OS X
By far the easiest option for OS X is to download the pre-built Mac Pronterface application. As of January, 2013 it can be found at this location. If you're running 10.7 or later you should already have Python and all the necessary libraries to run Pronterface-Mac, but if for some reason Pronterface-Mac won't run, you may have to go through a few extra steps. Instructions to set up OS X for Printrun (both pre-Lion and post-Lion) are posted at Printrun's GitHub project page.
Windows
To make it work on Windows, get the following packages and install:
- python (in case of problems with newer Python versions, try ActiveState Python)
- pyserial (official: only Win32, Python 2.5) or pyserial (unofficial builds: also support AMD64, newer Python versions)
- pyreadline
- wxPython
Or, use the ready-to-run version available at http://koti.kapsi.fi/~kliment/printrun/
Usage
With installation done, simply run the script, e.g.
CLI
You might also want to try a nice, unobtrusive command-line interface:
python pronsole.py
It features an online help function ("help" or "help <command>").
Troubleshooting
Good to know that the settings used by Pronterface are not stored in the app folder but in the user's folder (e.g : ~/.pronsolerc (GNU/Linux) C:\Users\yourname (Windows)).
'python goes SyntaxError'
Got an error similar to this?
[~] python pronterface.py File "pronterface.py", line 15 print _("WX is not installed. This program requires WX to run.") ^ SyntaxError: invalid syntax
This can happen if you use a GNU/Linux distribution such as Archlinux.
You can easily solve this by executing the following instead:
python2 pronterface.py
Connexion with printer failed
With some GNU/Linux distros, the python library used to connect to the printer doesn't accept some custom baudrates. To fix this issue, you must apply a patch to this library, following this steps:
Open a terminal window, and activate the pyserial library folder as current directory:
cd /usr/lib/python2.7/dist-packages/serial/
Download the patch in this directory (you must be root, or use the "sudo" command):
sudo wget http://sourceforge.net/p/pyserial/patches/_discuss/thread/ed3fb0de/f4fd/attachment/pyserial.patch
Make a backup of the original library:
sudo cp serialposix.py serialposix.py.bak
Apply the patch:
sudo patch serialposix.py pyserial.patch
Restart Pronterface, now the printer should connect. Sources: http://sourceforge.net/p/pyserial/patches/28/ and https://groups.google.com/forum/#!searchin/ultimaker/pyserial/ultimaker/BNjPpoJpfrE/gGSKAdhY5VwJ
Custom buttons don't appear
See also :
- http://www.emakershop.com/forum?vasthtmlaction=viewtopic&t=324
- http://www.emakershop.com/forum?vasthtmlaction=viewtopic&t=306.
