Printrun
Printrun is a set of G-code sending applications, written by Kliment. It consists of printcore (dumb G-code sender), pronsole (featured command line G-code sender), pronterface (featured G-code sender with graphical user interface), and a small collection of helpful scripts. Together with skeinforge they form a pretty powerful softwarecombo.
Installation
Linux & Distros
Dependencies
Before installing Printrun, make sure to install a few required libraries for both pronterface and skeinforge.
Depending on your Linux-distro, this can be done in several ways. The following is executed through the Terminal, often found under "Applications -> Accessories -> Terminal":
Debian
There are experimental packages for Debian (squeeze wheezy):
sudo echo "deb http://apt.ulrichard.ch/ squeeze main contrib non-free" >> /etc/apt/sources.list sudo apt-get update sudo apt-get install printrun-gui
Fedora
sudo yum install git pyserial wxPython tkinter
Ubuntu
sudo apt-get install python python-serial python-wxgtk2.8 python-tk git-core
There are also experimental packages for Ubuntu (maverick natty oneiric precise):
sudo apt-add-repository ppa:richi-paraeasy/ppa sudo apt-get update sudo apt-get install printrun-gui
Install & update script
Now you should install pronterface first, then skeinforge inside your pronterface installation directory.
This albeit little dirty but handy script does that for you!
(N.B it can also be used as a update script. Be sure to put your .stl-files etc outside of your Printrun directory)
BASEDIR="$HOME" #edit this is you don't want it installed in your home directory PRINTRUNDIR="$BASEDIR/Printrun" #Defines where the 'Printrun' directory is located. But of course you can change this to say: "$HOME/Documents/Create/RepRap/Printrun". SKEINFORGEDIR="$PRINTRUNDIR/skeinforge" #Defines where the 'skeisforge' directory is located in the 'Printrun' directory is located. cd $BASEDIR #Change directory to the executing users home directory. echo "Removing existing Printrun directory..." #Script being polite towards the user. rm -rf $PRINTRUNDIR #Removes the defined Printrun directory and _everything_ that resides in and beneath its directory tree. echo "Cloning Printrun..." #Script being polite towards the user. git clone https://github.com/kliment/Printrun.git #See also: http://help.github.com/linux-set-up-git/ echo "Grabbing skeinforge..." #Script being polite towards the user. wget -P /tmp http://fabmetheus.crsndoo.com/files/41_reprap_python_beanshell.zip #Uses good ol' wget for downloading skeinforge. echo "Unzipping skeinforge into Printrun directory..." #Script being polite towards the user. unzip -d $SKEINFORGEDIR /tmp/41_reprap_python_beanshell.zip #unzips the grabbed zip to ones defined skeinforge dir. echo "Symlinking skeinforge inside Printrun directory..." #Script being polite towards the user. ln -s $SKEINFORGEDIR/* $PRINTRUNDIR/ #Script makes a symbolic link. echo "Cleaning up temporary installation files..." #Script being polite towards the user. rm -rf /tmp/41_reprap_python_beanshell.zip #Removes tmp files.
Open a terminal window and copy the script above. Open nano by typing 'nano' in the windows prompt and hit return.
Save the script in a file named say 'PrintrunUpdate', make any adjustments if you want/need to. (Be aware the 41_* skeinforge Version is from 2011. The most recent version is 50_* which is from March 2012. Just change 41 to 50 or the most recent version).
Most likely you need to use the following:
chmod +x PrintrunUpdate
This will allow you to execute the script in the first place.
If you were to do this in your filemanager (Nautilus etc) it will ask you if you want to run this script.
Mac OSX
To make it work on OSX: (it's similar to linux in may ways, but different)
- see instructions for Lion, and pre-Lion here
Windows
To make it work on Windows, get the following packages and install:
Or, use the ready-to-run version available at http://koti.kapsi.fi/~kliment/printrun/
Usage
With installation done, simply run the script, e.g.
python pronterface.py
CLI
You might also want to try a nice, unobtrusive command-line interface:
python pronsole.py
It features an online help function ("help" or "help <command>").
Troubleshooting
Good to know that the settings used by Pronterface are not stored in the app folder but in the user's folder (e.g : ~/.pronsolerc (linux) C:\Users\yourname (windows)).
'python goes SyntaxError'
Got an error similar to this?
[~] python pronterface.py File "pronterface.py", line 15 print _("WX is not installed. This program requires WX to run.") ^ SyntaxError: invalid syntax
This can happen if you use a linux distribution such as Archlinux.
You can easily solve this by executing the following instead:
python2 pronterface.py
Custom buttons don't appear
See also :
