Prism
Release status: Working
Description | Mendel Frame
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
This extruded aluminum frame is an evolution of the original Mendel design. Most obvious is the move to extruded aluminum, which requires virtually no calibration yet yields a very square, rigid frame. Cabling is routed through the t-slots and held in place with printed clips, making it easy to hide, yet also easy to remove and reconfigure if needed.
The belt and single Z motor is retained from the original Mendel, but improved. Simpler belt routing reduces friction and the number of bearings, while making the belt easier to tension. This makes the z axis easy to calibrate, and less likely to skip, making z moves rock solid and consistent.
The Prism should have no problem fitting any Prusa or Sells X or Y axis, and the choice is left up to the user, though Prusa parts with linear bearings are suggested.
If you currently have a Mendel (particularly a Sells Mendel because of the belts and Z gears) this frame is quick, relatively cheap upgrade to give you even more rigidity.
Prism Specifications
Manufaturer | Reprap |
Model | Prism Mendel |
Technology | FFF/FDM |
Cost to build | $600 US |
Size | 440mm (W) x 440mm (L) x 410mm (H) |
Weight | ~7 kg |
Max Potential Build Envelope | 250mm (W) x 250mm (L) x 200mm (H) |
Prism vs. threaded-rod Mendel
Prism has the following key improvements over threaded-rod Mendel:
- Bigger print area in the X- and Z-axis directions
- Increased rigidity for better prints
- Simpler assembly
- Simple parts with few overhangs. (easier printing)
- Lighter and more portable
- Potential for light milling more likely
Why a Prism instead of a Prusa or Mendel?
The threaded rod Mendels will never be as rigid, pound for pound, as an extruded aluminum bot of similar design. It was hoped that the original Mendel would allow us to do some light milling, such as carve PCBs, but the frame lacked rigidity. The Prusa parts are even less rigid. Rigidity equals better quality at higher print speeds, as well as the potential for light milling.
Precut extrusions are also much more accurate than the average builder could hope for at home with a hacksaw. The advantage of getting the threaded rod at the local hardware store (if you live in a metric country) is greatly diminished by the fact that you will still need many components shipped, such as NEMA 17s, bearings, belts, pulleys, printed parts, etc. Without something as simple as a bench vice, cutting hardened steel threaded rods is a slow, tiring process (not to mention noisy, for you apartment dwellers).
The Prism frame can be assembled in just a couple hours with only an M3 and M4 hex wrench, and just briefly an M8 crescent wrench or a couple pairs of pliers. It's even faster with an electric screwdriver. By following a couple simple rules, the frame is assured to be square and aligned properly without measurement.
The Mendel's Z belt would bind and skip easily because it had a convoluted path and was hard to tension properly. However, a timing belt is an appropriate way to synchronize two gears. by forgoing the belt, the Prusa Mendel design introduced it's own problems, such as coupling the motor shaft to leadscrew. The Prism design keeps the timing belt of the Mendel, but simplifies both the belt path and the tensioning. A smaller belt could make the path even simpler.
So the Prism is quick and easy to assemble, like a Prusa, yet is even more rigid than a Sells, while making the z axis more reliable.
New non-printed parts
(Misumi parts numbers are listed, where applicable, for easy ordering; Not an endorsement. See also this list of alternative extrusion suppliers. )
- Extruded Aluminum Profile
- 20x20x400 - 9 (HFS5-2020-400)
- M3
- M3x10mm SHCS - ~10-20
- M3x15mm SHCS - 2
- M3 Nut - ~10
- M3 Washers - 2
- M4
- M4x12mm SHCS - ~70
- M4x20mm SHCS - 16
- M4 T-Nuts (which are compatible with your extrusion) - ~70 (HNKK5-4)
- M4 Washer - ~140
- NOT REQUIRED M4 Post-Assembly T-Nut - 20 will run about $10 - makes it easy to attach parts without having to disassemble the whole frame. (HNTA5-4)
- M8
- M8 Studding - 320-350mm x 2 - for the lead screws
- M8 Nuts - 6
- M8 Washers - ~20
- Smooth Rod
- 8mmx390-400mm - 2 - for Y axis
- 8mmx330mm - 2 - for Z axis
- Bearings
- 608 - 2 at least - for the lead screws
- 624 - 2 at least - for the belt runs
Printed Parts
Files
Up-to-date files will be on github: https://github.com/Buback/Prism-Reprap
Part Images
Optional pieces:
Build Instructions Notes
The Thick 90 degree part is mainly just to raise the printer up high enough so the z rods and motor shaft don't hit the table/workbench your printer is upon. You can use the thin part for all the vertexes but you're going to need to print out the spacer in order to get the proper height. The spacer/thin parts use much less plastic and print faster, but might not be as rigid --Buback 18:24, 27 December 2011 (UTC)
There isn't a dedicated X or Y axis for the Prism yet, but the frame as-is will work with anything that's compatible with a Mendel variant.
Visual Assembly Guide
Build the Prism fast.
For the quicker it is done,
the sooner you print.
--Buback 04:49, 29 December 2011 (UTC)
Add your X axis of choice now. Follow Lead-Screw Assembly instructions for Mendel
Further Development
-There isn't room at the top of the z rods to get a tool in and tighten the screws, which is why you need to put in the z rod first. I'm not pleased with this, and so the first order of business is to figure out a way to fix this. Adding longer 'arms' to the Ztop piece is the obvious solution, but then it's a longer unsupported angled print, which i feel leads to week parts. the other option is to split the part down the middle and make it two parts. the problem here is alignment becomes a bit of an issue, potentially. Anyway, if you'd like to design a part that holds a 8mm (or larger) rod in between two 20x20mm extrusions at a 60deg angle, feel free to post it here.
-Perhaps a dedicated Y and x carriage would be nice. I prefer a vertical X and ball bushings. The X build area could also be made bigger, but is now limited by the x length of the x carriage, and not by the space between the angled bars.
-Standardize a larger bed. it's defiantly possible to fit a 300mm x axis bed, though no current carriage/extruder design could print the whole thing. Y axis probably couldn't be much larger as is.
-Fully Parametric parts, a la OpenSCAD.
-A Circuit board mount that attaches to the bottom frame rails, under the bed.
-A travel case
