Prusa Mendel
Revision as of 14:08, 5 October 2010 by Prusajr (talk | contribs) (reduced image size)
Prusa Mendel
Release status: unknown
Prusa Mendel is simpler remix of normal Mendel.
Your-File-Name SOLID MODEL ASSEMBLY These are CAD files for the Solid Model Assembly .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name CAD FILES FOR PARTS These are CAD files for each part. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name EVEN MORE FILES These are are even more files. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)|-
Your-File-Name SOLID MODEL ASSEMBLY This is the final finished machine N/A --Example User 12:00, Tomorrow's Date, 20xx (UTC)
Please edit this and click the links to put in your own files! --Sebastien Bailard 08:34, 10 September 2010 (UTC)
Introduction
Prusa Mendel is simpler remix of normal Mendel. I want to use bushings instead of regular bearings, right now, my prototype is using two bearings, one for X and one for Y axis. Actual State is, that I have whole machine up and running, with my DIY PLA bushings. Its pretty smooth. <videoflash>tyVM3-v84I0</videoflash>
More info
http://blog.reprap.org/2010/10/story-of-simpler-mendel-pla-bushings.html
Where I can get actual files for parts
http://github.com/prusajr/PrusaMendel
BOM
(in works) M8 nut - 80x M8 washer - 76x
X-Carriage
X-End-Motor
Parallelnes of rods is ensured by the teardrop type of holes for rods plus securing bolts from bottom (there is nut bracket inside the part). By pushing the rods upside, they will self center.
X-End-idler
Universal Bar-Clamp
Frame-vertex
I use my mod of Vik's vertexes, slimmer, same sturdy as original :-) http://www.thingiverse.com/thing:2003 File:Frame-vertex.jpg
Other Links
Prusa's Blog
