Prusa i3 Acrylic
Revision as of 08:57, 22 September 2014 by Traumflug (talk | contribs) (Open Source?)
Open Source?
This pages neither contains nor links to design files, so it has to be assumed this i3 variant is actually Closed Source.
Prusa_i3_Acrylic Documentation
Prusa i3 Acrylic
Prusa i3 is a redesign by Prusajr.
unknown
The Prusa i3 Acrylic is a RepRap model originally designed by Josef Prusa. 3D Printer Czar redesigned its Acrylic Frame. Compared to its predecessors and other RepRap machines, Prusa i3 is known for its extreme ease of assembling, reliable printing, and dual extruder option. This kit uses laser-cut acrylic sheets to improve stability. In our experience, the Prusa i3 can be assembled within 3 hours, making it ideal for first-time RepRappers.
Technical Details
  • 8″x8″x7.25″ (20cm x 20cm x 18cm) Build Envelope
  • Electronics: Any RepRap electronics supporting 4 stepper motors.
  • 6mm Acrylic Sheets as Side Support
  • 0.4mm J-head MK IV Hotend
  • 50 micron Layer Height Aachievable
  • MK2A Heated Build Platform
  • GT2 Pulley’s and Belts
  • 12V 15A Power Supply
  • Greg Frost’s Greg’s Extruder
How to get it?
Included in the Prusa i3 Acrylic Kit:
Electronics
  • MK2A Heated Built Platform (wires and LED pre-soldered)
  • Nema 17 Stepper Motors x 5 (connectors and pins also included)
  • 12V 10A Power Supply
  • RAMPS 1.4 Shield
  • Mega 2560 R3 Control Board
  • Pololu Stepper Driver x 5 (with heat sinks)
Linear Motion
  • GT2 20-Tooth Aluminum Pulleys x 2
  • GT2 Timing Belt 1.7m
  • Hardened Zinc-Coated Precision Rods
  • LM8UU Bearings x 10
Tool Kit
  • 2m Tape Measure
  • Allen Wrench Set
  • 14mm Wrench
  • Circular File
  • Needle-nose Pliers
Miscellaneous
  • 3mm x 210mm x 200mm Borosilicate Glass plate
  • MKIV J-head hotend (1.75mm with 0.4mm orifice)
Q&A for Prusa i3 Acrylic
Shipping info removed. This is no shop here, it's the RepRap wiki. --Traumflug (talk) 17:33, 30 May 2014 (PDT)
