Prusa i3 Rework Introduction
Revision as of 11:51, 27 February 2015 by Traumflug (talk | contribs) (Mark as i3 derivate.)
Introduction | Bill of materials | Y-axis assembly | X-axis assembly | Connecting X-axis and Z-axis | Motor assembly
X and Y-axis motions | Heated bed assembly | Extruder assembly | Electronics and wiring | Marlin Firmware
Prusa i3 Rework
Prusa Mendel Iteration 3 rework based on the EiNSTeiN VARIANT.
The Prusa Mendel i3 is the third version of the open source 3D printer Prusa Mendel. Our version is based on an aluminium frame cut by water jet cutter and threaded rods. Axis motion is made on linear bearings, belts and pulleys or threaded rods and NEMA 17 motors.
The purpose of this document is to provide a visual guide needed to build a Prusa Mendel i3 3D Printer.
The machine and the assembly instructions are licensed by GPL.
Assembly instructions
Overview of the Prusa i3 Rework.
  1. Bill of materials
  2. Y-axis assembly
  3. X-axis assembly
  4. Connecting X-axis and Z-axis
  5. Motor assembly
  6. X and Y-axis motions
  7. Heated bed assembly
  8. Extruder assembly
  9. CNC Assembly
  10. Electronics and wiring
Parents
This design was inspired by older designs:
Improvements
This design changes several features from its parents.
  • Extruder upgrade: Magma Hotend (by Trinity Lab) support.
  • New cooling fan duct for Magma Hotend.
  • Y Idler with a tensioner system.
  • X End Idler with endstop holder.
  • Upgrade X End Idler in order to support 624 bearing.
  • Y Motor with endstop holder.
  • Addition of Z endstop Holder in situ.
  • Addition of a Dremel FlexShaft Attachment for 3 Axis CNC Milling.
Help and support
You can contact us with the following websites : eMotion Tech or Reprap-France.com par le biais de la rubrique Contact.
How to get it?
  • printable STL part files are available on Thingiverse and Github.
  • laser/waterjet cut DXF files are available on raw.githubusercontent.com/josefprusa/Prusa3-vanilla/master/src/alu-frame.dxf
