Prusa i3 Rework Introduction/tr
Revision as of 11:31, 26 March 2014 by Ali.Akdurak (talk | contribs)
Introduction | Bill of materials | Y-axis assembly | X-axis assembly | Connecting X-axis and Z-axis | Motor assembly
X and Y-axis motions | Heated bed assembly | Extruder assembly | Electronics and wiring | Marlin Firmware
Prusa i3 Rework
Prusa Mendel Iteration 3 rework based on the EiNSTeiN VARIANT.
Bu wiki sayfasının amacı size, kendi Prusa i3 Rework'ünüzü yapmanız için rehber olmaktır.
Bu sayfada anlatılan makine, toplama ve birleştirme yöntemlerinin tamamı GPL lisansı ile lisanslıdır.
Prusa i3 rework'e ait dosyalara buradan ulaşabilirsiniz :
Prusa Mendel i3 Sunumu
Prusa Mendel i3 Josef Prusa ve topluluk tarafından tasarlanan Prusa Mendel 3 Boyutlu yazıcısının 3 üncü iterasyonudur(irdeleme/tekrardan üzerinde çalışılması iyileştirilmesi anlamında). Bizim sürümümüz CNC kesim alüminyum çerçeveli model ve
The Prusa Mendel i3 is the third version of the open source 3D printer Prusa Mendel. Our version is based on an aluminium frame cut by water jet cutter and threaded rods. Axis motion are made on linear bearings, belts and pulleys or threaded rods and NEMA 17 motors.
Table of contents
Overview of the Prusa i3 Rework.
  1. Introduction
  2. Bill of materials
  3. Y-axis assembly
  4. X-axis assembly
  5. Connecting X-axis and Z-axis
  6. Motor assembly
  7. X and Y-axis motions
  8. Heated bed assembly
  9. Extruder assembly
  10. CNC Assembly
  11. Electronics and wiring
Improvements
  • Extruder upgrade: Magma Hotend (by Trinity Lab) support.
  • New cooling fan duct for Magma Hotend.
  • Y Idler with a tensioner system.
  • X End Idler with endstop holder.
  • Upgrade X End Idler in order to support 624 bearing.
  • Y Motor with endstop holder.
  • Addition of Z endstop Holder in situ.
  • Addition of a Dremel FlexShaft Attachment for 3 Axis CNC Milling.
Sources
Help and support
You can contact us with the following websites : eMotion Tech ou Reprap-France.com par le biais de la rubrique Contact.
