Prusa i3 Rework X axis assembly
Revision as of 06:47, 9 November 2014 by Dark Alchemist (talk | contribs) (X End Idler & X End Motor assembly)
Introduction | Bill of materials | Y-axis assembly | X-axis assembly | Connecting X-axis and Z-axis | Motor assembly
X and Y-axis motions | Heated bed assembly | Extruder assembly | Electronics and wiring | Marlin Firmware
Needed parts :
  • X End Idler
  • X End Motor
  • 1x 624 ball bearing
  • 4x LM8UU linear bearing
  • 1x Endstop
  • 2x M5 nut
  • 1x M4x20 mm screw
  • 1x M4 nut
  • 2x M3x14 mm screw
  • 2x M3 nut
Please take note that Step 1 is if you are using the vanilla Prusa I3 and is not required if you use the RP designed for the Reworked version found at https://www.thingiverse.com/thing:119616
Step 1
Drill with an 8 mm drill X End Idler and X End Motor holes (displayed in green). Do not drill deeper than 20 mm on the X End Motor. Set counterclockwise rotation and drill progressively and carefully along the axis.
Drilling X End Idler and X End Motor holes.
Step 2
Push two LM8UU linear bearings in the X End Idler and two LM8UU linear bearings in the X End Motor. They can be pushed with hands but you can use a rubber mallet carefully if necessary.
Inserting LM8UU linear bearings.
Step 3
Insert an 624 ball bearing (the smallest) between the X End Idler and slide an M4x20 mm screw.
You may have to force the screw into the part but on the Rework's RP (link above) simply screw the M4 into both sides but do not force it. Fix them with a M4 nut and tighten slightly.
624 ball bearing assembly in the X End Idler.
Step 4
Insert two M5 nuts in their marks. In order to do that, thread a threaded rod M5x300mm opposite to the nut. Slightly heat the nut using a lighter or a blowtorch then pull the rod. Be careful with this operation.
M5 nuts assembly.
Please note that Step 5 will not work with the SainSmart endstops as the wiring harness on the endstops gives zero room for any nuts or screws to attach the endstop to the Idler. The only way to fix this is to use a flat head screw from the side with the cable wiring harness. Even then 14mm is way too long and 8-10mm would be adequate.
Step 5
Affix one endstop with two M3x14 screws and two M3 nuts on the X End Idler.
X-axis endstop assembly.
X Carriage
Inserting LM8UU linear bearings on the X Carriage.
Needed parts :
  • X Carriage
  • Zip-ties
Insert four LM8UU linear bearings on the X Carriage and fix them with eight zip-ties. Make sure to put the « head » of the zip-tie on bearings side.
X-Axis assembly
X-Axis assembly.
Step 1
Push two smooth rods Ø8x370 mm through the X End Motor. Use a rubber mallet carefully if necessary. The excess length is about 345 mm.
Step 2
Slide the X Carriage assembly carefully through smooth rods.
Step 3
Insert the X End Idler assembly and adjust the distance between both Z-axis (about 362 mm).
