RAMPS 1.5
Revision as of 20:44, 30 November 2018 by NinthDimension (talk | contribs)
Version specific info
RAMPS 1.7 | RAMPS 1.6 | RAMPS 1.5 | RAMPS 1.4.4 | RAMPS 1.4 | RAMPS 1.3 | RAMPS 1.2 (RAMPS 1.2 old) and older
RAMPS 1.5
Release status: Working
RepRap Arduino Mega Pololu Shield Arduino MEGA based modular RepRap electronics.
none
none
The RAMPS 1.5 is a variation of the popular RAMPS boards that, like all other RAMPS boards, is plugged into an Arduino Mega for operation. The layout of the RAMPS 1.5 is virtually identical to that of the RAMPS 1.4. The only real difference between the two are the MOSFETs and the fuses.
Comparison With Other RAMPS Versions
Both use the same mosfet but simply have them installed differently: the RAMPS 1.4 has them oriented sideways with a heatsink in away that allows it to be easily plugged and unplugged; the RAMPS 1.5 has the mosfets soldered flush to the surface with flush heatsinks on the bottom of the board.
The RAMPS 1.5 uses small soldered fuses rather than the large yellow fuses prone to breakage on the RAMPS 1.4.
Gallery
