RAMPS 1.5
Revision as of 19:09, 2 December 2018 by NinthDimension (talk | contribs) (nullified license)
Version specific info
RAMPS 1.7 | RAMPS 1.6 | RAMPS 1.5 | RAMPS 1.4.4 | RAMPS 1.4 | RAMPS 1.3 | RAMPS 1.2 (RAMPS 1.2 old) and older
RAMPS 1.5
Release status: Working
RepRap Arduino Mega Pololu Shield Arduino MEGA based modular RepRap electronics.
none
none
The RAMPS 1.5 is a variation of the popular RAMPS boards that, like all other RAMPS boards, is plugged into an Arduino Mega for operation. The layout of the RAMPS 1.5 is virtually identical to that of the RAMPS 1.4. The only real difference between the two are the MOSFETs and the fuses.
It is important to note that the RAMPS 1.6 is not developed by UltiMachine, the original developer of the RAMPS boards. It is designed and manufactured by BIQU/BIGTREETECH based on the original RAMPS designs but they have not open-sourced the designs yet.
Comparison With Other RAMPS Versions
Both use the same mosfet but simply have them installed differently: the RAMPS 1.4 has them oriented sideways with a heatsink in away that allows it to be easily plugged and unplugged; the RAMPS 1.5 has the mosfets soldered flush to the surface with flush heatsinks on the bottom of the board.
The RAMPS 1.5 uses small surface-mounted fuses rather than the large yellow fuses prone to breakage on the RAMPS 1.4. The downside is that replacing the fuses becomes much more difficult.
Gallery
