RAMPS 1.7 LCD/ru
Revision as of 07:19, 6 March 2019 by Edlab (talk | contribs)
RAMPS17-LCD
Состояние выпуска: Прототип
Описание Плата подключения ЖКИ индикатора к блокам RAMPS.
Лицензия GPL
Автор MrAlvin
Соавторы
На основе Pololu Electronics
Категории RAMPS 32-bit board 8/16-bit board
CAD модели нет
Ссылка на внешний ресурс нет
As I were developing the RAMPS 1.7 and RAMPS 1.4.4 shields, I discovered that creating LCD add-on boards would be an interesting way to do further testing and/or add easy-connect functionality to these RAMPS shields.
RAMPS 1.7 - LCD-03
Краткое описание
This LCD board accommodates RepRapDiscount LCDs, both Text and Full Graphics versions, via the EXP-1 and EXP-2 ports
Additionally:
  • As the RAMPS 1.7 shield does not have an AUX-2 connector, this LCD board has an AUX-6 connector, which simulates the AUX-2 port, so it becomes possible to connect LCD displays to the RAMPS 1.7 shield, where the LCD is otherwise designed to connect to the AUX-2 port of a standard RAMPS board.
  • The AUX-3+ connector is duplicated on this board, so it easy to connect SPI items, together with a RRD LCD display.
  • On the RRD LCDs there are provisions for the addition of a Stop or Reset button. This option already has a dedicated wire in the EXP-2 port connector. This wire can be directly connected to the Arduino Reset pin or to D45, by setting jumper J2 on the LCD-03 board.
Файлы
Плата LCD-03 устанавливается на плату RAMPS 1.7C
Файлы Gerber
Sprint-Layout Файлы печатой платы
Где взять плату RAMPS 1.7 - LCD-03
На данный момент Вы можете загрузить Gerber файлы и отправить их производителю печатных плат. This is however a very low cost, and simple and very straightforward activity by now (2019).
You can check out DirtyPCB, SeeedStudio, JLCPCB, AllPCB, and more, they all produce good and very useful PCBs.
RAMPS 1.7 - LCD-01
Универсальный двунаправленный 3V <=> 5V конвертер для всех контактов на разъёмах Aux-3+ и Aux-4.
Ссылка на Github
