RBS/Beam
Revision as of 22:33, 21 January 2010 by Bodgeit (talk | contribs) (Wood Construction Debris)
File:RBS Beam.jpg
Sourcing
RepRap-Made
File:Rbs beam made with reprap.jpg
LaserCut-Made
File:Rbs beam laser cut.jpg
Solid
You can make RBS beam from cutting 1/2" sheet with a laser cutter.
Hollow
You can make hollow square beams 1"x1" beams or 2"x2" beams from thin plywood sheet. Just cut long thin, dovetail-edged strips, 1" or 2" wide and glue them together.
Steel
United states
  • Any construction steel supplier.
  • McMaster Carr "steel structural tubing"
  • Unistrut
Canada
  • Unistrut
(This should be a table)
UK
  • Any construction steel supplier. (Undrilled)
  • predrilled?
Aluminum
United states
  • Unistrut
Canada
  • Unistrut
UK
Perforated
Undrilled
(The same folk who sold you all your mendel rod.)
Dexion Speedframe
This is a high-strength shelving system made from cheap steel square tubes and unimportant but elegant interconnectors.
The tubes are a lovely 1" (25.4mm) square x 10 ft (3048mm aka '3m') long.
  • Speedframe (1" square x 3048mm long) x 1 length
£20.00 per 3m length http://www.tradesystems.co.uk/acatalog/Dexion-SpeedFrame-25mm-Square-Tube-System.html?gclid=CO20puGvvJ4CFQQMDQodVCn5Cg
  • Buy Used! Shelving outlives many a business plan, so check your telephone directory under 'shelving/racking'.
You may get lucky, and pay £10/3m rather than £20/3m. http://shop.instant-shop.com/stodec/category740226.html
  • Used/offpbrand
http://www.richardsonsuk.co.uk/productdetails.php?product=74
Wood
Warning
In North America, wood which is called '1x1' or '2x2' is actually smaller than 1 inch or 2 inches in cross section. This is unfortunate but legal. Speak to a lumber yard or other supplier about getting 'wood which is actually sized 1 inch by 1 inch or 2 inches by 2 inches'. They will be able to help you, possibly by setting up a small order correctly sized material with a local mill, which may be a quick job. (If you are a woodworker, this paragraph is obvious, and we apologize. And you have a table saw.)
Imperial
  • 1"x1" or 2"x2"
Metric
18mm x 18mm or 44mm x 44mm (Metric)
Construction Debris
It's plausible that we can use Eiffel or similar to mill construction debris wood down to 1"x1".
Notes
  • Nails - After checking carefully with a nail finder.
  • Grit - Use a stiff plastic brush to clean off your wood. Stone pebbles will chip your saw blade.
Working Notes, ignore below this line
  • Eiffel should be able to drill the beams for daughter machines.
  • 1"x1" or 2"x2" (Imperial)
  • 18mm x 18mm or 44mm x 44mm (Metric)
Inspiration
