RP alternatives
Revision as of 18:54, 12 March 2013 by DavidCary (talk | contribs) (PLA bushings)
Many alternative parts exist to replace to the standard RP parts published in the wiki for each reprap platform. Users must be aware that simply because a part may be listed as an 'alternative,' it does not imply that the the part may be a full drop in replacement. Please use discretion if you are formulating a BOM for a new tool build!
Idea for this page (will remove later):
If available, list the Pro's and Con's of the alternative piece.
Mendel
Prusa
Description Links to alternative Image of original
coupling Greg's 3 jaw coupling: http://www.thingiverse.com/thing:8675
Nophead's Z Coupling: http://www.thingiverse.com/thing:9622
Jay's Z coupling: http://www.thingiverse.com/thing:7059
Tinker Z: http://www.thingiverse.com/thing:12190
x-carriage Greg's x: http://www.thingiverse.com/thing:9869
CngReprap's http://www.thingiverse.com/thing:14930
x-end-idler jonaskuehling's improved idler: http://www.thingiverse.com/thing:18384 Pm-x-idler.jpg
x-end-motor jonaskuehling's improved end-motor: http://www.thingiverse.com/thing:18384 Pm-x-motor.jpg
y-motor-bracket Clip on prusa Y bracket: http://www.thingiverse.com/thing:10823
Prusa Y Motor Mount EZ: http://www.thingiverse.com/thing:13393
Y motor mount torsion box http://www.thingiverse.com/thing:11017
z-motor-mount Integrated Z Motor Mount: http://www.thingiverse.com/thing:11838 Pm-z-motor.jpg
belt-clamp Y Axis Belt Tensioner: http://www.thingiverse.com/thing:10274 Pm-belt-clamp.jpg
bar-clamp 2-way Prusa Bar Clamp: http://www.thingiverse.com/thing:5786 Pm-bar-clamp.jpg
frame-vertex with foot MV6: http://www.thingiverse.com/thing:4773
Vik's Vertex: http://www.thingiverse.com/thing:2003
Triffid's Vertex: http://www.thingiverse.com/thing:12313
jnfischer's Vertex: http://www.thingiverse.com/thing:5094
frame-vertex MV6: http://www.thingiverse.com/thing:4773
Low Warp/Shelled: http://www.thingiverse.com/thing:2413
Elk's economized Vertex: http://www.thingiverse.com/thing:15274
pla-bushing RP-PLA;
PLA bushings
crossbraces Frame triangulation along X axis:
Full crossbracing for Prusa http://www.thingiverse.com/thing:15606
Lateral support for Prusa http://www.thingiverse.com/thing:14606
