RUG/Australia/Suppliers
Revision as of 02:37, 3 January 2013 by Cefiar (talk | contribs) (Reprap/3D Specific Suppliers)
Australian Suppliers
We've broken up the page into a number of sections to make it easier to find stuff. Feel free to add suppliers as you find/purchase from them.
Notes
  1. Some of the suppliers here are not "Australian owned", but they all have offices in Australia. Some places may ship parts from overseas to fill an order. Most places deliver anywhere in Australia, unless otherwise noted.
  2. Any prices listed here are indicative only, and should be checked for correctness before ordering.
  3. Cheaper prices at overseas websites may be announced in IRC (see also wikipedia's entry on IRC), however shipping costs may eclipse any savings. While you are in IRC, you can ask if 'whatever website' is a reputable retailer. Caveat emptor should still apply when shopping online.
These suppliers specifically sell to the 3D printing community, usually targetting Reprap or related 3D printing systems.
Full kits
  • Emblem Robotics - Complete Prusa Mendel kit with modifications, free shipping Australia wide!
Printed Parts
  • Create3D - Prusa Iteration 2 kit with substantial modifications and substitutions to improve ease of build and robustness. Also happy to print any other random part.
Hot Ends/Extruders
  • VIC Extrude3D - Hot ends using their own derivative of a J-head design, with nozzles from 0.25mm to 0.5mm, for 3mm and 1.75mm filament (Bowden 3mm only), and 12V or 24V setups. Also sell printed herringbone gears to suit a Wades extruder.
Bearings/Bushings/Belts/Gears
Mechanical
General
Bearings
Fasteners
Allthread/Studding
AKA "Threaded Rod" or "Booker Rod". Also check Fastener suppliers. Note that any Studding used as a drive rod should always be Stainless Steel. Some people have used Galvanised rod for the frame.
Rod/Round Bar
T-Slot profile
This is used in the MendelMax design.
  • SES Linear Bearings - Ships from Melbourne. Offices in VIC, NSW, QLD, WA, SA & NZ. Note that their T-slot nuts have M4 holes.
Belt
Springs
  • QLD Small Parts and Bearings
  • VIC CSW Products Will sell in small quantities at the door. Currently testing C9 and C20 springs for a wades.
  • VIC Whelans Springs May need to place a largeish order.
  • Bunnings Currently testing "Utility Comp Spring C-608" with Adrian's Geared Extruder and spring loading. These springs are somewhat expensive, costing just under $5 for a pack of 3 (the updated nozzle design requires 4). The smaller C-582 springs just manage to fit an M4 bolt but the wire itself is so thin that it occasionally slips through the very narrow gap between an M4 bolt head and its washer; there's also a greater chance of them catching the threads.
"Kapton" Polyimide adhesive film
  • NSW Ultrakeet Mail order Australia wide, they supply 5mm, 10mm and 25mm Tape - 33 Metre rolls.
  • NSW BilbyCNC Mail order Australia wide, Supply 6mm,20mm,50mm - 33 Metre rolls.
Electronics
General
Arduino
Arduino is an open source electronics prototyping platform. "Clones" or "fully compatible Arduino" boards may be available. Use your favourite search engine to find them. Build quality, reliability and after sales support of clones may vary. Currently (Nov 2011), the Arduino Mega 2560 board (based on the ATmega 2560) is an update to the Arduino Mega (based on the ATmega 1280). Some 1280 based boards are still being sold.
Stepper Motors
  • NSW AusXMods Sell a very powerful NEMA17 and lots of NEMA23 motors.
  • VIC HomannDesigns Currently only stock NEMA23 motors. Listed for the future Mendel Apollo makers ;-)
  • VIC OceanControls Have mix of motors, drivers and controllers.
  • WA RobotGear Only seem to carry 2 steppers, one of which is powerful enough for a Mendel or Mendel-variant.
Nichrome Wire
Pololu
A4983
A4988
Feedstock
  • VIC Complete Plastic Welding Supplies 26 Nov 2011 -> Website is old and prices in the catalog may be out of date, please update *this page* if the linked website is updated.
  • VIC Lybina ABS in 3mm and can supply very large rolls. They are considering extruding PLA (determining interest). Other materials and sizes a possibility, depending on volume and the material.
  • NSW BilbyCNC PLA and ABS in 1.75mm and 3mm in a wide variety of colours and also sell glow in the dark and colour-changing filament.
  • NSW Oz Reprap Supplies PLA and ABS in 1.75mm and 3mm.
  • NSW Create3D ABS in 3mm and 1.75mm. Also used to stock PLA (not listed on their site any more).
  • SA 3DPrinterGear ABS and PLA in 3mm and 1.75mm. Also Laywoo-D3, Taulman 618 Nylon and Crysta-Line Blue/Yellow/Red/Transparent ABS.
  • VIC 3D Printer Bits ABS in 3mm with 1.75mm upon request.
  • NZ Diamond Age ABS & PLA in 1.75mm and 3mm. While they're in NZ, they're reasonably close enough to class as local.
Tools
Below is a sortable table, click the icon beside the column heading to change which column to sort by.
Supplier State Suburb Notes
Belic Tools VIC Box Hill and Dandenong Very large range of tools and accessories.
Bunnings Aus wide Standard hardware store. Useful if you need generic stuff, but not always cheapest.
Cost Less Bolts (Moorabbin/Cheltenham) VIC 3 Ebden St, Moorabbin 3189 Tools and accessories related to bolts and nuts. No web store (unfortunately)
Cost Less Bolts (Ringwood) VIC 13 Molan St, Ringwood, 3134 Tools and accessories related to bolts and nuts. No web store (unfortunately).
Dick Smith Aus wide Sadly, carrying less and less tools.
H.E. Supplies Pty Ltd QLD 186 Wecker Road, Mansfield, 4122 Sells a lot of tool accessories including drill bits, burrs, bits, etc. Note: Store-front version of Small Parts and Bearings.
Home Hardware Aus wide Standard hardware store. Useful if you need generic stuff, but not always cheapest.
Jaycar Aus wide Carry a fair range of electronics tools.
McJing Tools NSW 454 Hume Highway(Liverpool Rd), Yagoona, 2199 Engineering and Woodwork tools
Mitre 10 Aus wide Standard hardware store. Useful if you need generic stuff, but not always cheapest.
MyToolStore QLD Aspley, 4034 Online sales of Dremel, Proxxon, Bosch, Kincrome, and other tools. Also sells CNC's and mini-lathes.
Small Parts and Bearings QLD Mansfield Sells a lot of tool accessories including drill bits, burrs, bits, etc. Note: Online version of H.E. Supplies Pty Ltd.
Note
Many suppliers of electronics and mechanical parts also sell tools, usually related to their field of expertise. It's always worth checking them out, even if only for ideas, as the cost can sometimes be much more expensive.
Links
There are lots of other sites on the net that have useful lists of suppliers for all sorts of things. Any of the local HackerSpaces are definitely worth checking out for this sort of stuff. You can ask in IRC if you need more information. Below are a few links that may be relevant:
CCHS Hardware Resources - Melbourne HackerSpace Hardware Resources page.
