RUG/Pennsylvania/State College/Electronics/Heated Bed
Revision as of 19:51, 28 April 2011 by Dpd5061 (talk | contribs)
Introduction
Printing ABS or HDPE plastics using the mendel often results in warpage rendering the print useless. These deformations are due to moderate temperature gradients which develop in the plastic as a result of cooling. For example hot plastic from the extruder may leave the tip at 200 degrees Celsius while the base layer of the plastic part has cooled to room temperature. This temperature difference can be especially prevalent in larger prints causing noticeable distortions, lifting of the print off the bed, and interruption of the print. Experiments have shown that heating the print bed up to approximately 120 degrees Celsius has significantly reduced warp problems http://hydraraptor.blogspot.com/2010/01/will-it-stick.html.
The purpose of this page is to discuss an analysis for a preliminary design of a mendel heated bed. This evaluation takes into account mechanical design considerations, general heat transfer analysis, as well as material costs and options.
References
[1]http://hydraraptor.blogspot.com/2010/01/will-it-stick.html
