RUG/Pennsylvania/State College/Mullis/Code Generator
Revision as of 11:13, 27 October 2014 by Glenn (talk | contribs) (+Category:RUG, Pennsylvania, State College)
Overview
Below is the code for a project being written to allow users of the Mullis machine to be able to edit variables in the G-Code such as tray unit length and feed rate.
mullis_v1.3.py Sample Code
#!/usr/bin/python # # Mullis GCode Creator # Version 1.3 # By: Andrew Selzer # Copyleft 2012 # # Changes: Added ability to write G-Code without comments. v1.1 # Changes: Added ability to adjust motor speed. v1.2. # Changes: Added ability to adjust tray adjustment unit length. Removed unnessary comments. v1.3. # print "Welcome to Mullis GCode creator Version 1.3!\n"; # Ask User For Tray Unit Length tray_query = raw_input ("Would would like the length the tray is loaded adjusted? (Please input yes or no)\n"); if tray_query in ('yes', 'YES', 'Yes', 'y', 'Y'): tray_value = raw_input ("\nPlease input unit length value: \n"); print "\nYou have selected "+tray_value+" as your unit length value. \n"; else: tray_value = 2500 print "\nThe default unit length value of 2500 will be used. \n"; # Ask User For Feedrate feedrate_query = raw_input ("Would you like the motor speed adjusted? (Please input yes or no)\n"); if feedrate_query in ('yes', 'YES', 'Yes', 'y', 'Y'): feedrate = raw_input ("\nPlease input motor speed value: \n"); print "\nYou have selected "+feedrate+" as your motor speed. \n"; else: feedrate = 50000 print "\nThe default motor speed of 50000 will be used. \n"; # Ask User For Comments comments = raw_input( "Would you like your code with comments? (Please input yes or no)\n"); # Opens a File fo = open("mullis.gcode", "wb") if comments in ('yes','YES','Yes','y','Y'): # Print Statement for Comments Enabled print "\nThis GCode will be generated with Comments Enabled.\n"; # Writes G-Code to File fo.write("M28 X18 ; home x axis\n\n") fo.write("G91 ; use relative positioning\n\n") fo.write("G1 X10 F2200 ; these three lines are the header\n\n") fo.write("G1 F"+str(feedrate)+" ; this is the speed of the motor, adjust it to make the extruder go faster or slower \n\n") fo.write("G1 E"+str(tray_value)+" ; Lower tray for a length of units. To go farther, adjust the number after the E (extrude).\n\n") fo.write("G4 P30000 ; this is the pause command. P is the time paused in milliseconds.\n\n") fo.write("G1 F"+str(feedrate)+"\n\n") fo.write("G1 E-"+str(tray_value)+" ; this moves the extruder backwards, retracting the PCR tray\n\n") fo.write("G1 F2200\n\n") fo.write("G1 X250 F2200 ; this moves the x carriage to the next bath. the number after the F controls the speed (feedrate).\n\n") fo.write("G1 F"+str(feedrate)+"\n\n") fo.write("G1 E"+str(tray_value)+" F"+str(feedrate)+" ; Lower PCR tray (2500 steps is default value)\n\n") fo.write("G4 P30000 ; pause for 30 seconds\n\n") fo.write("G1 E-"+str(tray_value)+" F"+str(feedrate)+" ; Raise PCR tray (2500 steps is default value)\n\n") fo.write("G1 F2200\n\n") fo.write("G1 X-250 F2200 ; move PCR tray to first bath.\n\n") # Close Opened File fo.close() elif comments in ('no','NO','No','n','N'): # Print Statement for Comments Diabled
