RUG/Pennsylvania/State College/Presentation
What's New?
3.29.11: Unit One is alive, as is our class' first Mendel!
3.5.11: One class Mendel is alive and printing, and everything but a ribbon cable is in place for Unit One.
2.24.11: Our PSU class' repraps are nearing completion, with a Huxley and Mendel all but fully assembled and programmed, and our third close behind. With a bit of luck, all three should be online and ready for their maiden prints within the week.
Meetings
- Tuesdays: Intercollegiate Future Society will be forming up next week in the Willard lobby @ 8pm, and we will be commondeering a room from there.
- Thursdays:: PSU Reprap class meeting in 305 Hammond @ 5:15pm until 9ish.
Prototyping systems in development
Projects
- Tip Profiles
- TechZone InfoHub
- Waste Reclamation System
- 3D Scanner Projects
- Imperial Reprap SAE
- RUG/Pennsylvania/State College/Heated Bed
Model Files
Universal Pen Holder for Mendel
This is a set of files for a Universal Pen Holder made to be mounted on a Mendel Unit. As it is currently designed, you would also need a 6/32 threaded rod and at least 4 nutts of the same type. You also need 6 screws that will be threaded into the holes in the hexegon shaped parts. These screws are used to hold the pen in place, use whatever screws can screw snugly into the holes.
Alternative Z-opto Holder
This is an alternative holder for the Z opto endstop. Instead of using the screw and spring that is typically packaged with the Mendel kit, this can be used instead. With this design, turning the threaded shaft clockwise lowers the linkage. Turning the shaft counter clockwise raises the linkage.
One known issue with this design is that the two screws connecting the bottom 2 bars to the base block come loose with time allowing the entire linkage to lean to one side or another. Finding a way to stablize the bars attached to the base block would solidify this design.
- Z-opto Holder (Solidworks Assembly)
- Bar (Solidworks Part)
- Base (Solidworks Part)
- LockBlock (Solidworks Part)
- NuttBlock (Solidworks Part)
- Handle (Solidworks Part)
- Bar(STL)
- Base(STL)
- LockBlock(STL)
- NuttBlock(STL)
- Handle (STL)
Useful Links
- Gcode for RepRaps
- Good guide to Skeinforge
- Skeinforge PLA Profile
- Gen6 SF Settings
- All About Patents
- Plugins for Sketchup file to export .stl
- AccuTrans3D (trial version) stl file editor and save
Firmware and Files
- File:EMFApr29profiles.rar - Skeinforge Profiles
- File:EMFApr29alterations.rar - Skeinforge Alterations
- File:EMFapr29awk.rar - AWK Directory
- File:FirmwareforOneWireAD heatbed brnrd 20110317.zip - documented here
- File:Emf Bestextruder4 07.rar - A copy of the extruder code we have been using with max endstops enabled.
- File:Psu Bestmobocode2 24 2011.rar - TZ Gen3 Mobo code altered for our machines
- File:Extruder class jpj12 2011-04-07 temp fix.pde - Modified version of Bestextruder4_07 with brnrd's fix for temp overflow bug.
- File:SC Skeinforge Mar24.rar - Skeinforge Settings as of March 24
Members
Copy and edit the following from "Example User" to your own handle to add yourself to the membership list:
