RUG/Pennsylvania/State College/Printers/PSU Blue and White
This page is for information about the PSU 3D printing Unit Blue and White. This printer is designed to be an Open Hybrid Mendel, or OHM for short. This printer is part of the Penn State class EDSGN 497J. The project was originally started in Spring 2013 but was only a frame at the end of that semester. It was worked on again in the Fall Semester when the final assembly was finally finished at the end of November 2013. The printer was worked on by Penn State College of Engineering undergraduates ranging from sophomores to seniors. The majority of those involved with the project had no or little RepRap or 3D printing experience at the start of the project and most had to learn as the build required more knowledge of the printer.
The Blue and White printer had all its parts printed with PLA by other RepRap machines. The printer will mostly be printing with PLA but has the potential for ABS. It will see use in creating other RepRap machines for the Spring 2014 semester.
Current Team
Lee Schwartz, [[User:Tonyarm|Tony Armlin], [[User:Tmt5147|Todd Troutman], [[User:Ypc5015|Yuan Chai], Graham Deever
Log
Date | Status |
12/05/2013 | Updated wiki page to show current status. Printer has all components added and is awaiting testing and callibration. |
11/14/2013 | Printer is awaiting electronics. All other components are finished. |
11/7/2013 | Printer X-axis is completely assembled. |
8/29/2013 | Blue and White build is continued. Just the frame built. |
Spring 2013 | Blue and White build is started. |
2/18/2014 | Blue and White rejoin repair, extruder assembled, wires reconnected, limit switches adjusted. |
2/20/2014 | The distance between 2 Y-axis was adjusted, replaced the right connection part at bottom. |
2/25/2014 | Reconnected the right Z-axis, adjusted the plate, movement correct, extruding testing. |
2/27/2014 | Blue and White started work, filament entrance bolt tightened, extruding motor's gear replacing. |
4/29/2014 | The blue and white printer is currently working but could be printing better. The y-axis is off and results in elongated prints. The printer in general requires more calibration. The extruder tip also leaks melted plastic near the top of it while printing. It is still currently unknown why the extruder is leaking and where exactly the fracture or gap in the extruder is located. |
Operating Specifications
Design | Ohm |
Electronics | RAMPS |
Firmware | Marlin |
Extruder | 0.35mm |
Gallery
About this printer
This printer is designed to be an Open Hybrid Mendel, or OHM for short. It is finished and as of last class needs to be tested and calibrated.
Builders
Build Team | ||||||||||
Leo Funk | ||||||||||
Oyenola Adeola Ogunro | ||||||||||
Justin Frazier | ||||||||||
Dimitar Dimitrov |
