RUG/Pennsylvania/State College/Printers/PSU Unit Green
This page is for information about the PSU Unit Green. This unit is of the Mendel/Prusa hybrid variety. All of the printed parts were printed in PLA by other units in our group.
Operating Specifications
Operating Specifications | |||||||
Name | Status | Design | Electronics | Firmware | Extruder | Temperature | Comments |
Green | Not Working | Ohm | Monotronics | ??? |
202C | Mount new Z-Axis gear on further filed motor shaft |
PSU Unit Green - Current Condition
Features
- Electronics
- TechZone monotronics.
- Extruder
- Greg's accessible extruder with techzone extruder tip and thermocouple.
Works in Progress
- Spool Holder
- Working on making an easily foldable, and funtional spool holder.
- currently testing, will upload results when finished
- HPB
- Heated Build Plate is being implemented. Almost fully functional.
Troubleshooting
Most likely to least likely:
- Extruder
- Stuttering:
- 4-pin connector on the board needs reseated (unplug, replug).
- Not Extruding:
- Idler tension too tight (digs hole in PLA) or too lose.
- Uneven Extrusion:
- Gears not making proper contact. There is currently a black plate between the extruder motor and chassis in order to keep the gears flush.
- Idler not doing it's job.
- Cold Extrusion Prevented:
- If this occurs before a print, you can warm the tip manually with your hand until it reaches a temperature where it will set temp. You can fix this forever by reflashing the min temp for extrusion in the firmware.
- Chassis
- Prints not filling properly and/or skewed lines in XY:
- Gears on X/Y motors have come loose, and need reseated and tightened on the flush part of the motor shaft.
- Belts are too lose.
- Gears on the motors are bad and the belts are slipping on them.
Builders
