RUG/Pennsylvania/State College/Printers/PSU Unit Mondo
Revision as of 19:50, 4 October 2012 by Afs2015 (talk | contribs) (Operating Specifications: Standardized status column according to new specifications.)
On this page you will find the current status of the Unit M Mondo. Our Mendel Unit is a Techzone laser-cut Mondo. So far, no major design components have been changed from what you get from Techzone. Eventually the plan is to use this large unit with a dual extruder. Much more information can be found at RUG/Pennsylvania/State_College/Dual_Extruder
We are having trouble getting the Techzone thermocouple and tip board working with Ramps. Currently we are using an additional thermistor attached to the hot tip, but this is causing a lower temperature to be read by the board.
Slic3r Configuration File
Here is our current configuration file for the PSU Mondo:
Spring 2012
File:Mondo.ini.txt
Name Status Design Electronics Firmware Extruder Temperature Comments
Mondo Mondo Not Working Mondo Ramps V1.4 Marlin ??? 200C Mostly Assembled, Tuning Required
Build Status
What has been done: Frame assembly, Electronics installation, Replaced Thermistor with Thermocouple, Adjusted Steps/mm, Adjusted BOD rate to in Marlin to 115200, Tuning of Motor steps/mm.
Mostly up and Working, small adjustments may be needed.
What needs to be done: Fine tuning of Slic3r settings (Current Slic3r configuration file coming soon). Some motor belt adjustment may be required. Exact bed size to be determined.
State College RepRap Users Group
S.C.R.U.G. Main · The Make Space · Intercollegiate Future Society · Wiki Help
