RUG/Pennsylvania/State College/Printers/PSU Unit Purple
Revision as of 00:13, 27 March 2014 by Npm5073 (talk | contribs) (Log)
Purple
Color: Purple
Extruder: .35mm
Temperature: 190C
This page is for information about the PSU Unit Purple, which is assembled and undergoing testing. This unit will follow the design of the Ohm. All of the printable parts are printed in PLA and assembled. The purple printer was constructed by Matt R, Deanna M, Bill F, and Yaqi Y.
Log
Date Modification / Problem
3/20/13 The Purple Printer found a new home in Hershey PA.
2/12/14 The carriage was replaced due to bad gear mesh.
12/05/13 The new board is being flashed. Bad RAMPS/Arduino, will not connect.
11/16/13 Consitantly printing good prints now. Could possibly use a fan for cooling-Crosby
10/11/13 Working pretty good. Table needs leveling and x axis is slightly out of alignment but still does decent prints.-Crosby
Unknown The filament hole in the extruder body needs aligned with the metal plate and hot tip. Disassembly of the extruder will be necessary.
Operating Specifications
Name Status Design Electronics Firmware Extruder Temperature Comments
Purple Green operational Ohm Ramps Marlin 190C Extruder motor overheats on longer prints
Pictures
Builders
Build Team
Bill Fabrizi
Deanna Moschitta
Matt Rockar
YaqiYang
Maintenance Team
Maintenance Team
Zachary Cameron
Sam Carroll
Benjamin Gorenc
Jessica Mewkalo
Nate Myer
State College RepRap Users Group
S.C.R.U.G. Main · The Make Space · Intercollegiate Future Society · Wiki Help
