RUG/Pennsylvania/State College/Printers/PSU Unit White
Revision as of 00:32, 9 December 2013 by Tunkelbs (talk | contribs)
White
Color: White
Extruder: .35mm
Temperature: 200C
This page is for information about the PSU Unit White (Ψ). This unit is of the Mendel/Prusia hybrid variety. All of the printed parts were printed by other units in our group. The printer has a heated bed, use it at 60C.
Log
Date Modification / Problem
12/06/2013 Extruder Gear skipping slightly
09/03/2013 X-Axis pulleys must be changed
Operating Specifications
Design Ohm
Electronics RAMBO 1.4
Firmware
Extruder 0.35mm
Heated Bed Yes
PSU Unit White - Current Condition
Print Problems And Solutions
PROBLEM
SOLUTION
Prints were leaning to one side.
Reattached the Y-axis pulley securely.
Motors were getting very hot.
Adjusted the potentiometers so the motors had just enough power to drive the axis and run the extruder.
Tip temp. read '2511' in Repsnapper.
Reconnected thermocouple more securely.
Extruder motor gear slipping.
Super-glued gear to motor shaft.
The extruder bolt was mis-alinged so the filament was not feeding.
Adjusted the spacing of the extruder bolt with washers.
Assorted Prints
Video
<videoflash type="youtube">NUG-33G0zaU?hd=1</videoflash>
Operators
This machine was assembled by:
  • Nicholas Whalen
  • Michael Testa
This machine is currently operated by:
  • Di Wang
  • Kunal Bansal
State College RepRap Users Group
S.C.R.U.G. Main · The Make Space · Intercollegiate Future Society · Wiki Help
