RUG/Pennsylvania/State College/Printers/PSU Unit Yellow
Introduction
This page is dedicated to the PSU Unit Yellow 3D printer. This unit will follow the design of the Open Hybrid Mendel developed by students of the EDSGN 497 class at The Pennsylvania State University.
Operating Specifications
Operating Specifications | |||||||
Name | Status | Design | Electronics | Firmware | Extruder | Running Temp | Comments |
Yellow | Running | Ohm | RAMPS | ??? | ??? | 204C |
Works in Progress
Class Log
1/22/2013: Leveled the bed plate on our COM3 printer. Tried to run a few prints with minor success. COM3 still needs fine tuning and some bugs worked out with the extruder. Extruder drive gears are not meshing properly causing the motor to click or skip. Some setup work was done to COM5 to get it soon ready to print. Tightened some slides and drive belts in hopes to get it up and running next class. Was experiencing some issues driving the one axis. Next time: Continue tuning both printers.
1/24/2013: COM3 printer was still experiencing problems with the extruder. The extruder was replace with the one off of COM5 printer. After readjusting the axis limits, the COM3 printer was extruding very well. It successfully printed three small parts. Some of the axis were skewed. Minor tunings were made to the frame to straighten the prints. More tuning is necessary to get quality prints. COM5 is down due to no extruder, z drive motors acting goofy, y axis motor twitches after being used.
2/12/13 Fix y axis belts to prevent zip tie contact with rods. Tighten x axis belt and extruder.
2/16/13 As a team, we spent some time working some more bugs out of the system. For some reason the printer does not like to connect to the computer and will not communicate. If you close out of printerinterface, reopen the program and try to reconnect it will....sometimes. We also tweaked the slicer configurations. If printing a small part, we will use the small part configuration, and large part slicer for large parts. We included more skirting to help keep the part from lifting off the bed. We also have a fan to help cool the part while it is printing. The fan is really helping keep small parts from getting soft deforming. Please see yellow team log book with the printers for latest updates.
Builders
Spring 2013 Yellow team:
Btz5006, Djl5217, Vatlark, MarkKeller22
