RUG/Pennsylvania/State College/Software/Python scripts
Revision as of 13:52, 22 January 2014 by Aem28 (talk | contribs) (Python scripts and command line)
Overview
Python is an open-source programming language. Its syntax is simple, however it includes many powerful tools, making it easy to create and edit files through a script. Python in the RepRap context can help generating or editing gcode, or generating 3D objects.
Two branches of Python are being used: Python 2.x and Python 3.x (more details: http://wiki.python.org/moin/Python2orPython3). Their syntax is slightly different, and a script written in one version won't work with the other. The version used should be specified at the beginning of the python file holding the script. Both versions can be downloaded at http://www.python.org/download/.
Most Unix systems (MacOs X, Ubuntu, Fedora...) come with Python 2.7 packages installed, so you won't need to install them again. However, you'll need to install Python 3.x to run Python 3.x scripts. Both versions of Python can co-exist on a computer without creating problems.
Once Python is installed, you can write and run scripts from the Python software. However, it's generally easier to use the command line interpreter to run scripts, especially when one wants to edit another file.
On Windows
To run a Python script on Windows, open the command interpreter (look for cmd.exe). Then, use the following commands:
Change the current directory to the directory where the script is. Note that cmd.exe will write the path for you if you drag and drop a folder in its window.
cd path/to/the/script/folder
Enter the name of the python script, with its extension. Some scripts also required arguments, which must be added after the name of the script, with a white-space between them.
example.py argument1 argument2
On Unix systems (Mac and Linux)
To run a Python script on Mac or Linux, open the terminal (located in the Utilities folder on MacOs X). Then, use the following commands:
Change the current directory to the directory where the script is. Note that the terminal will write the path for you if you drag and drop a folder in its window.
Enter the name of the python script, with its extension. Some scripts also required arguments, which must be added after the name of the script, with a white-space between them. To tell the system that you want to run a 2.7 Python script, add 'python' before the name of the script. If you want to run a Python 3 script, add 'python3'.
python3 example.py argument1 argument2
Useful scripts
Python scripts and Blender
